Line Lock
Simcoe Ontario
2016 Mustang GT, 24 Bronco, 15 Ram
Ok, so I have a 2016 Mustang GT Premium with the 6 speed manual, and I have used line lock a few times before, and now it doesn't allow me too, I go through the steps to get it set up and right when it says click OK to start it says line lock unavailable see owners manual, what is happening and what do I need to do to make it work? and yes the advance track is off before I start.
coyote550
NY/NJ
Alex
2016 Mustang GT Premium 6MT PP1; 2020 BMW X3 M40i
I don't mean to sound like an cuck but are you holding the brake pedal while you press ok? Cause I messed up like that several times when I just got the car. Also easy to forget if you haven't used it in a while. The process is usually like this:
1) Hold OK to start line lock
2) Push hard on brake (hard as you can)
3) Keep holding brake (don't move it an inch) then click OK
4) Smoke 'em
If its not that, could be a track apps issue. Some people reported glitches in the software.
I usually just do it the old fashioned way. Way too many steps to set up the dang line lock. Just be sure the pull the "dyno plug" or the loop plug first (and plug it back in when you're done). It completely disables your TC and AdvanceTrac. It's located between the airbox and driver's side fender. You'll see a plug that goes nowhere basically.
Twisted_Mallais
Simcoe Ontario
4) Smoke 'em
Ya Im pretty sure I have held the break the entire time. BUT maybe I do left off a bit to soon, I'll have to try it when I get my car back from the shop. and ya I have a kill switch hooked up to that loop plug so I can shut it off from inside my car as I need it.
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
Car warmed completely up? I know my 22 model wouldn't engage when the engine wasn't completely up to temp. Mine was an auto though. Also have to be on level ground.
NGOT8R
Adrian
2019 Bullitt
Parking brake must also be off. Press the brake pedal to the floor HARD!
I also have the 580Performance switch connected to the nanny plug u set the hood. Don’t turn off TC/Adv Trac with your switch u til after you complete your burnout using line lock, otherwise line lock will be grayed out and unusable.
Twisted_Mallais
Simcoe Ontario
Good to know about not shutting the switch off until after as far as the breaks I do push breaks down hard until the box fill sup and moves to next step. and the Ebrake is always off
NGOT8R
Adrian
2019 Bullitt
Follow the prompts and stay on the brakes until the timer activates.
Twisted_Mallais
Simcoe Ontario
I follow the prompts all the way through, Ive done it before and its worked fine a few times, just all off a sudden it doesnt allow me to anymore
NGOT8R
Adrian
2019 Bullitt
Only other thing I can think of then is the switch you have connected to your nanny plug. I only mine off (TC/Adv Trac) with my switch that I have connected to my nanny plug, after I roll out of the burnout.
Twisted_Mallais
Simcoe Ontario
I cant remember if I had it shut off or on when I tried it last, I'm going to have to try again and see what it does with it off
RMoeslein
Pittsburgh
Rich
2022 Mustang Mach 1, 2020 f250 lariat Tremor
make sure car is level, e brake off, transmission in 1st gear(obviously clutch in). My 19 pp2 used to give me that message, it was one of the 3 above. I ended up installing an aftermarket line lock that i bought from lethal performance because the factory LL was finicky at the track and i didnt like the inconsistency. Im going to do the same on my M1 so i can have line lock and the wheel speed sensor unplugged. On my 22 mach1, if i disconnect the wheel speed sensor, it completely disables line lock.
Paddles
TX
Richie
2023 Mustang GT
Make sure it's in Track mode
