How to disable the Active Noise Control
MakStang
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
Yeah, it's good when you have the stock exhaust on. You will need to disable it though once you go with a louder system such as a race or competition one.
StealthStang
South Africa
2016 Roush Ecoboost (NX2)
Hell,I wish I had more synth sound.i like it.
The problem is once you start upgrading the system with more powerful aftermarket amps and speakers the synthetic sound is just a horrible distorted mess. It just doesnt scale up well at all.
StealthStang
South Africa
thx for info in thread
Miami EB
Miami, FL
2017 Lightning Blue EB 200A + Nav
does the Ford Pro Cal tune really disable this? I have a really loud MBRP Race catback and it seems to have helped it a bit.....or maybe it's all in my head lol
PonyFresh
Seattle
2017 Mustang Ecobooost
Well I have to say by unplug the socket, the cabin noise gets worse...
MakStang
MakStang
Greece
www.cellentis.uk
Makis
Unplugging the mic on the rear headliner (if this is what you are referring to) definitely quiets it down a bit. This has been confirmed by several people. However the best way is to do it through FORScan (which I’ve done and I can confirm that it works), or through the method described by [MENTION=20216]acull2000[/MENTION] above.
FraG
Western Australia
MY17 EcoBoost
I bought myself the a module for the Forscan so will turn off the crappy synth when my exhaust finally goes on :) As the module is coming ex HK, I'll be able to report on the difference in drone if any :)
MakStang
MakStang
Greece
www.cellentis.uk
Makis
[MENTION=28329]FraG[/MENTION] be aware that you are not disabling the synth but rather the Active Noise Cancellation with this method. The fake engine noise is still there, but it won’t bother you at all, as your exhaust will be louder.
Ebm
North Carolina
Guy
'14 GT
I believe I heard someone mention the Ford Pro Cal tune does get rid of synth sound.
MakStang
MakStang
Greece
www.cellentis.uk
Makis
How do you depin the connector. Do you simply pull the wires?
MakStang
MakStang
Greece
www.cellentis.uk
Makis
Thanks [MENTION=20216]acull2000[/MENTION]
TorqueMan
St. Jacob, IL
2017 EcoBoost Premium
According to post 59 of this thread, GTs have a sound tube running from the intake to the firewall. That can be removed and capped off.
In any case, in the EcoBoost the ANC can be deactivated as described in the following post:
http://www.mustang6g.com/forums/showpost.php?p=1668885&postcount=1196
Hmmm. That post says to change the digit from "A" (ANC enabled) to "8" (ANC disabled). This is different from other instructions I've seen saying to change the "A" to "0", which worked for my car.
