How often to change mt82 fluid?
Metz3020827
Arizona
Connor
2017 Mustang GT
My car has 55k miles on it (17 GT PP) and I’m not sure if it’s ever been changed since I bought it used. I don’t drive it very hard anymore, usually 6th gear cruising on the highway. I am getting suspension overhauled Sunday but I want to do the transmission fluid soon.. have I waited too long?
no weird noises/shifts besides clunky 1-2 shift
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Changed mine at 30k. Calimer cocktail.
Gonna do it again at 60k.
But no ATF garbage.
Full on full synthetic 75w120. Wildhorse cocktail.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
But no ATF garbage.
Is it easy to do yourself?
Sevensixteen
New jersey
Brian
2020 mustang GT, MT-82, 2024 Bronco, Big Bend, SAS
Like taking candy from a baby, just remember to remove the fill plug first. If you drain the fluid first & can’t refill it, then that’s a problem !
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
I think every 60k is perfectly fine unless your car is used as a learner often lol. I changed mine pretty early to get out any break in material but it came out nearly perfect.
Nope, I’m the only person who drives my car. People driving a manual now a days is a rarity
Torched10
Atlanta
Bob
Just did my tranny.brakes.coolant fluids and differential fluids.since you bought it used might want do them all
[/QUOTE]
Sparky1337
VA
2016 Ruby Red GT
I did mine at 30k with the OP Mustang kit. I am fairly rough on it plus my 1-2 shift is almost impossible when it’s colder than 45 outside. The BG fluid helped a bit when it warms up.
subframe
New Hampshire
Richard
2019 Bullitt 2014 F350
Got my 2019 Bullitt in 2022 with a little over 14,000 miles on it.
I changed the fluid my first winter with Calimer recommened Amsoil 75w-90 manual transaxle gear lube. That was a flush. Replaced it again the next winter with the same thing and installed a MGW shifter, The transmission works perfectly.
