How much difference does a supercharger make ?
m3incorp
Georgia/Colorado
James
You learn to roll in to the power, regardless of the tires on the street. Smash the go pedal and yep you will be spinning tires.
How do you guys put the power down? Stock power on a 2020 6spd burns the tires at the top of 1st and 2nd. I’m sure better tires would make a big difference...that said, my dad has a 2007 GT500 with just an intake/tune (probably not even 500 wheel hp) and fresh 305 Michelin PSS aren’t enough to use all of that power.
MRGTX
CT
2020 Mustang GT 6spd base
LOL... yeah. Even my NA/low compression, carbureted small block will blow off the tires if you just mash the pedal. With the GT500 especially, even when carefully rolling into the power, the tires were overwhelmed at WOT in the lower gears.
As cool as superchargers are, I'm not sure how much quicker they will be on the street compared to a well set up NA car. This comment doesn't apply to "honk honk honk go" roll racing nonsense from higher speeds (since the boosted power will be much more valuable as speeds climb) and I'm sure that people will come up with exceptions but I'm speaking in generalities here. Stop light to stoplight, the extra power isn't that useful.
As a general rule, a relatively heavy car like our Mustangs, there seems to be a soft-performance limit with a front engine/2wd layout on street tires, somewhere in the low 11s. To go much quicker, you need to drop a bunch of weight or run drag tires.
You don't need 850hp to get to the low 11s...Actually, a gen 3 Coyote with an A10 and E85 is pretty much there.
Of course, if you're building a car specifically for the track with appropriate tires, the supercharger will earn its keep. On the street, not so sure. Even in stock form, these cars are powerful enough that it comes down to driver and traction more than peak power numbers.
Andrew@Lethal
West Palm Beach Florida
Andrew
Hey guys, so I'm looking at Supercharger kits. And I just want to know, how big of a difference does it make in the ride after they installed? How noticeable are they? Is the difference actually night and day ? Can you justify the price for them
Night and day difference for sure. There are more entry kits like Roush and Edelbrock, then there are more upgradable kits like the whipples, VMPs, Prochargers, Paxtons/Vortechs which can squeeze a lot more horsepower. We sell them all here at www.lethalperformance.com
Jmtoast
Michigan
2018 Roush GT
The speed at which you end up in the ditch is greatly increased.
tj@steeda
Timothy
Just make sure ... when you add that power, you are also addressing ways to keep the power to the ground.
Power is fun ... but spinning isn't :(
Adamone92
California
Adam
2022 Mustang GT PP Premium
my 315/35/17 toyo r888r has been hooking pretty well on the street with my odin supercharger kit on my 2018.
Jmtoast
Michigan
2018 Roush GT
They lasted one summer for me.
wtb6mtv8rwd
California
Kevin
SOLD
How much weight does a complete kit like a Whipple add?
Does your front sit lower after the install?
Do you notice the handling being more front heavy?
noac
Tom
Mustangs
Highly recommend the Roush. Watch the the Brenspeed video on YouTube. Great power, safe tune and warranty up to $11.5.
S550AC11
Dixon, CA
Aaron
17 PP GT
The weight is significant with the whipple gen 5 stage 2. My first ride in the car felt like I mounted a snow plow. I have Steeda minimum drop springs and shocks and thought it'd work great in preparation for boost, but I was dead wrong. NA it felt incredibly balanced and controlled while looking great too. I'm in process to move to a coil over setup so everything in front is fully adjustable.
As far as power it's also night and day difference. 435 NA with headers and E tune to 804 hp sae on E85, limited by rpm on dyno do to speed at 7650. Power was still climbing. 612 rwtq at 5000 ish rpm so the power band is really broad. I run standard 3.87 pulley which is 11psi. Big block mid range with top end of good centri setup.
jayman33
Fort Bragg, NC
Jason
24 GT
Huge difference, fast and powerful. When you think of the cost per HP, power adders are legit! Let us know if we can help! www.hypermotive.com #veteranowned
