High Speed Cruising Alignment Specs
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
Looking for alignment specs recommendations. I know there are a couple people on here with lots of suspensions knowledge (@BmacIL @Bluemustang @Roadway 5.0). Looking to see what they, and anyone else for that matter, recommend for this specific alignment.
2019 Mustang GT no PP, Steeda minimum drop springs, Ford track shocks/struts, Steeda alignment dowels and bushing locks, camber bolts if needed. I am not a corner carver, though I do enjoy a spirited backroad drive, I’m either going under the speed limit in town or 120mph+ on the autobahn. Looking for a good all around alignment set up, with a focus on high speed stability, to tell the shop after suspension install.
Thanks for any help.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Front
Camber: -1.5
Caster will end up around 7.0
Toe: 0.02-0.05 per side, 0.00 steer ahead
Rear
Camber: -1.2-1.3
Toe: 0.10-0.12 per side, 0.00 thrust angle
Enjoy!
mejohn50
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
Thanks to both of you for getting back to me. Also realized I forgot @Norm Peterson as one of the suspension gurus. I know there's more people, but I have learned a lot from the ones I tagged. I found an alignment shop close by that looks like it can take care of that to my specs. Just waiting on a couple more tools and parts and I will be doing the install. Then a trip to the Nuerburgring now that it's open.
valentinoamoro
US
15 TY Mustang GT
Thanks.
Front
Camber: -1.5
Rear
Camber: -1.2-1.3
Enjoy!
Thanks. So are you recommending toe-in? I went for .05 toe-out. Can you explain the difference (pros and cons) of each? I'm due for an alignment soon.
Also, on a related note - does spacers in the front wheel increase steering feedback?
PTM5.0
MO, IL, and KY
'18 GT PP A10
Front
Camber: -1.5
Rear
Camber: -1.2-1.3
Enjoy!
Thanks for the specs! I had HPJ Performance set the alignment on my car going off your recommendation when they were prepping my car for a 1/2 mile event coming up and the car feels great at 150+mph.
BmacIL
Enginerd
Naperville, IL
Thanks.
Toe out will increase turn-in response at the expense of stability (twitchy steering) and corner exit grip in the front. Toe in does the opposite. Both will increase initial steering feel, though.
Spacers will increase steering feedback and effort.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
How can both toe in and toe out increase initial steering feel? In my experience, toe out makes the steering lighter (more turn for less effort), and toe in makes the steering heavier, more self centering, and less initial turnin. They dont both increase “feel” whatever feel means.
FWIW mid corner, toe in is (according to others) supposed to make the car more prone to oversteer (outside front loaded tire is turned in a bit) and toe out makes the car understeer (outside front tire is turned out slightly)
BmacIL
Enginerd
Naperville, IL
It means they both induce a small slip angle on the tire and thus produce more feedback/weight initially than zero. At very small toe angles it's pretty subtle though.
And your second part, we agree. You just stated it better.
mejohn50
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
Front
Camber: -1.5
Rear
Camber: -1.2-1.3
Enjoy!
To be clear, the toe measurements are degrees right? One more since it's been years since I have done an alignment. Positive toe is toe IN?
BmacIL
Enginerd
Naperville, IL
Correct for both.
mejohn50
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
Suspension install and alignment done. On a road trip right now that took me through some really open stretches of autobahn. Huge difference in stability at speed now. Thanks to everyone for the input.
