HELP! Rear Subframe bolt Cross Threaded
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
Damn.... I just did the BMR kit this weekend and the whole job only took 2 hours - but almost a full hour of that was trying to get the left front bolt back in without cross-threading it. Only worked it by hand so I could feel instantly when it would start to bind, but it was super frustrating. I do feel a little better knowing that it's not something *I* specifically f'ed up tho.
I'm glad it wasn't only me . hahaha
I had hell getting everything tightened back up after my spring and shock install.
I didn't strip the big blue bolt but both of the smaller ones next too it. I had to tap it and it was fine. But I've worked on a lot cars over the years can't remember one being such a pain in the ass when getting bolts back in.
FordMustacheGT
Northeast
2015 Ford Mustang GT
I ran into some trouble getting the front, driver’s-side bolt started couple weeks ago and one thing that helped a lot was using a jack to raise the subframe all the way up to the chassis before starting the final bolt as opposed to trying to start the bolt with the subframe in the lowered position and drawing the subframe upwards with the bolt. I’d already gotten the passenger side bolts somewhat snug at that point.
I think there’s so little play between the alignment inserts and the subframe bolts that you really just need the bolt to be pointed in the right direction to start it without risking cross threading.
TeeLew
So Cal
Tim
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
This thread did help me a lot by having me ready to look for cross threading. I was able to get it done without a crossthread but it was a pain in the ass. and i was very careful to get them in by hand many turns before sending them home.
Hostil
IL
Randy
2015 Mustang GT
On my way to Harbor Freight.... So much for "being back on the road in no time"! ugh
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
I tried Anti Seize on my shock bolt I almost fked up,it was a little cross threaded and
the Anti Seize for some reason worked (old time trick)
Or youll need a tap...
I hate the way new cars have threads in the frame this way and not a nut and bolt
config
I ran into the same on the rear lower control arm shock bolts. Bought brand new bolts and everything. I had to run a tap through it. I think this starts at the factory with expedience over diligence.
Robottrainer
Canada
Thank you very much for your reply, I tried to do that first, but the issue I ran into was that I do not have a socket that fits over the end of this. They are either too big, or too small. I tried it with the one that fit the closest, and whenever there was resistance it just slipped over the end. That seemed like the easiest as well as the best solution for me as well.
You need a square head bolt socket. It's an eight point socket. Probably 1/4"
Robottrainer
Canada
Are you trying to put the 4th one in, after the other three are tight?
If so, loosen them ALL up....and let the cradle hang down about 1" (gap between the body and top bushings) then address the one you are having issues with, first. Thread it in about half way....then caddy corner the next one...then just tighten them up like .25" at a time.
It is a pita, but can be done. Most people will "distort" the cradle slightly when centering it due to OEM tolerances.
This is a very good reason why we didnt "perfectly" center the cradle with the CB005 Kit....but just made it "more centered" - we had you guys in mind during the install.
Good luck!
It's probably why there is all that adjustment in the toe links.
Robottrainer
Canada
I had them all loose, had two pry bars and no help. I'm a fairly strong guy. I think something has to be wrong with the car's bolt hole. All three lined up loose and went in hand tight, the fourth started hand tight just fine and stopped. I can't wrap my head around the fact that three line up and the fourth doesn't. That doesn't make sense, if the two on the right and lined up, there's absolutely no play in those alignment pieces. That shit goes in straight lol. The cradle should be square with the other side. Hence the rear going in no problem. We are talking millimeters off here across a span of a few feet, I understand it's going to be stupid tight, but that's down right insane.
There is a stud kit available. A bit easier on the threads
BigD94
New Jersey
Dom
2016 GT
Hey guys. Need some help here.
I did the CB005 install yesterday and it was all good until the front passenger bolt. The other three went in fine, but this one would tighten about 4 turns by hand then get difficult. I knew about the issue with cross threading so I took a lot of time with ratchet strap trying to align it better to no avail. Ended up getting it into the best position I could and tightened with a ratchet. It was not nearly as easy as the other 3 bolts, but I never hit any crazy resistance.
The issue is that when I got to the end of tightening the bolt, it stopped getting tighter and just started spinning. There’s still resistancebut it’s just spinning.
Am I cooked guys? Anyone know what tf the issue is here? šŸ˜”
@BMR Tech
offroadkarter
Lehigh Valley, PA
offroadkarter.smugmug.com
2016 Mustang GT PP
@BMR Tech
Pull the bolt out and see if the threads look boogered up. If you're lucky, it was just pushing thru some crap. Important to make sure the threads are clean on these bolts and bolt holes since this is such a finicky install.
DougS550
Fishers, Indiana
Doug
I just installed centering spacers with my bmr cb005 and cb762 level 2. I also installed Kalltrec ancor bolt kit. I had to jack the subframe up just untill all sides lightly touched. Then using a 30" pry bar I moved the subframe and screwed each ancor bolt I by hand. Then I torqued them down in three steps, front left, right rear. Left rear and front right. Now when I have to lower my sub frame I will never have to worry about cross threading the frame nuts. I did use thread chasers on all of my nut plates to clean the threads up. Unless absolutely nessasay, I try. Not to use taps unless absolutely nessasary for they cut the nut plate pretty hard. I didn't tighten or torque the bmr stuff untill subframe was torqued.
tosha
Canada
Mustang GT PP1
@BMR Tech
Have you fixed it? Just curious what is the diagnosis
