HELP! Rear Subframe bolt Cross Threaded
jdoug
Regular Guy
SoFla
Doug
2019 Mustang GT A10
Glad it worked out for you, kinda. I also used a temporary bolt that I got from Ace Hardware until I could get a real Ford bolt. It held up just fine for the two or so days.
Commbubba19
Omaha
2017 GT
Also having the issue with the driver's front.
I'm doing the BMR cradle kit. I've loosened all 4 bolts. Then removed the driver's front and rear. Put in the kit and then raised the cradle up via a jack. I started the rear by hand and then the front. The front started a few turns with ease and then i used a ratchet. Sure enough it got tight quick and i immediately backed it out and tried again. I noticed each time that once it got difficult, material was being removed from the threads when i removed the bolt. Pic below (ignore the steeds alignment spacers, not using them).
I made extra extra care that the threads wouldn't be stripped. There was no lateral load on the bolt, i was lined up perfectly.
Not sure if a Tap of the hole is the next step. I'm kind of stuck at the moment until I get this resolved.
16s550
Bay area
2016 GT M6 performance pack, whipple charged
I left that alignment bushing out. Only installed three and my alignment in rear was all green. When I install the 4th I'm just going to a shop that had lift. I think that's the easiest way to get the 4th one in.
Silentskorn
Sacramento, CA
Brandon
2015 Mustang GT Premium
I had a similar issue when I installed the alignment kit and Steeda Support Bushings. I was able to insert 3 of the subframe bolts except the front driver's side. Ended up buying the tap and die kit from Harbor Freight. I think part of the issue is all the debris that gets stuck in the threads. Multiple passes with the tap helps alot.
Niz55
Us
17 GT350
When it doesn't go in don't force it. Realign the hole with a pry bar and slowly thread the bolt in. I have done this many many many time and never cross threaded anything.
If you are in Orange County CA, I can come over and help you out.
16s550
Bay area
I almost feel like I ruined the threads by trying to align it with the pry bar. I feel like driving down to socal so you can help me. Lol. :)
Commbubba19
Omaha
2017 GT
i ordered a 14x2 tap and die. It's just so weird how easily it got cross threaded. Just sucks the car has to sit like this for probably a week or more until the tap arrives.
Has anyone swapped out the blue sub frame bolts for better grade 8 bolts that aren't designed for self tapping?
16s550
Bay area
There's no harbor frieght near you? That's where I found the right tap.
K-Roll302
Southfield, MI
Karl
'17 Mustang GT Premium, '80 Porsche 924 Turbo
Sorry for bumping an old thread but I'm desperate to know. Would a cross threaded subframe bolt drilled all the way in by the dealership cause a clunk sound that sounds like something metal knocking around in the trunk? If so, I've found my culprit.
jbailer
Joe
See answer in other thread.
Doctor Fishtail
Mexico
Mustang GT
No. If it is stripped in the frame rail it is actually an easy fix. My drivers front stripped and had it fixed in 20-30 minutes. :thumbsup:
jbailer
Joe
Why do you say no? It's actually very likely if it's cross threaded the installer could have stopped at the correct torque and the subframe still not be tight. That is a very likely cause of the knocking sound. It would be very easy to take the bolt back out, check the condition of the threads, run a tap if needed and replace the bolt to proper torque specs.
K-Roll302
Southfield, MI
Karl
No Harbor Freight or O'Reily's near me had a 14 mm x 2.0 tap. I've ordered a new bolt, but I need to order the right tap online now. Are the threads right or left handed?
xXANCHORMONXx
SF CA
2016 GT350 Track Pack
I've done maybe 20 cb005 installs
It is easy peezy,
There is no way you will every cross thread anything if you put the bolt in by hand.
If you feel resistance 9/10 times it will not fix itself.
