[HELP] - New Rim/Tire Setup?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
You can go with actual PP2 wheels and then you can rock 305's all around. There is always that option
or go with APEX SM-10 wheels and a 11” wide all round w/ no spacers. Similar to PP2 offsets but actually fit better, stronger and lighter than the PP2 cast wheels. Probably cheaper too.
The common track rat 11” square setup uses extended studs and slip on spacers (and camber plates) so the up front costs are a little higher, but the use of spacers lets you run the same wheel offsets (ET52) front and rear so you can rotate wheels to even out wear. The no spacer setups are square 305 tires but different wheel offsets on the front (ET26) to fit w/ extended studs and slip on or bolt on spacers.
m3incorp
Georgia/Colorado
James
Are you set on having a square setup, or just want it because that is what you see on the PP2 car? Are you open to 20" wheel options. There are so many options out there...and as posted above, if you like the PP2 wheels, get a set of those and run square 305 all around.
KT3
KT3
Toronto
Jay m
2019 Mustang GT
what’s the part number ?
