GT500 Radiator
DB83
Granny Shifter
Spain
2017 Mustang GT
Anyone know if the the GT500 uses a larger radiator than the GTPP/GT350 radiator? If so, is it a direct swap to the GTPP?
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
Following for info.
EFI
Masshole central
5.Br0
Did you ever get anymore info on this? I'm looking to swap out the base GT rad and was initially going to go with the 350/PP unit but it would be awesome if the 500 one was better but still fit.
EFI
Masshole central
5.Br0
If you want better, Mishimoto is the way to go
I ran that for about a year and several track days, saw about the same temps as with the OEM unit. Certainly wasn't a big improvement, marginal at best. That's why I'm looking for a true upgrade and was hoping to stay with OEM reliability hence looking into the 500 unit if it's any different/better.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I am on OEM PP radiator. Extra oil cooler. I drained 1 gallon of coolant and replaced it with 1 gallon distilled water. I think that helped a little.
Even better would be 100% water with two bottles of Water Wetter, but I wouldn't do that in cold climate location.
wingnutt
@FL410
michael
350R Procharged w/P1X
gotcha! for me, running hard in the 100+ degree days with the big intercooler, the stocker just couldn’t pull it off…got the dreaded wrench with ECT, CHT and limp mode warnings, but the Mishy fixed all that 😉
EFI
Masshole central
5.Br0
I never got those perse, just hitting some "soft" limits that I have in my head for what is safe or not. So maybe I just wasn't pushing the Mishi enough to see a difference, and at my levels of comfort both produced the same result.
What temps were you hitting before and after?
wingnutt
@FL410
michael
I honestly have no idea…watched everything like a hawk for the first thousand miles but failed to realize that was springtime. Fired up to come home one of the first 100+ days, found a turbo SS to mess with along the way, and whammo 🤨
galaxy
St Louis
'17 GT350
I have the Mishi also. I think sometimes the benefits of a bigger, more capable radiator may be misunderstood. Correct, you're not going to see cooler temps, but you will see not as hot of temps, and more stability. For me, post tune, I know this - my cooling fans would kick on high (100%) when needed; traffic, stop-and-go, long periods of idle, etc. Now with my Mishi, I have yet to hear my fans run on high in same conditions. Such has been my experience anyways. My fans kick on low (60% I believe) and my CHT's do not move. YMMV.
EFI
Masshole central
5.Br0
I wasn't talking about cooler temps on the street as those are kinda moot. With both radiators I was seeing 192-196 CHTs while cruising so you're correct no cooler temps because they're ultimately limited by the thermostat. But on track, they both maxed out around 237-240 in similar temps so was seeing just as high CHTs with both.
