OppoLock
RWD Addict
- Apr 21, 2014
- St. Petersburg, FL
- Sean
- '15 GT, '20 GT350
- Vehicle Showcase
- 1
Bulking is taking in an excess amount of calories beyond what you need to maintain your current weight. So if you burn around 2500 calories on an average day, you would consume something beyond that (like 2750-3000) with an appropriate macro setup (macronutrients being proteins, carbs, and fats; usually measured in grams). The general rule of thumb is that you want to consume at least one gram of protein per your lean body mass (total body weight less your bodyfat weight - usually a rough approximation at best found by estimating your bodyfat percentage) along with a sufficient amount of carbs and fats.Umm.. What?
I'm sure this is great advice if you speak the lingo, but can you translate for those of us who don't speak LA Fitness..?
Done right, you'll break your muscles down at the gym (or wherever with whatever kind of training), refuel them with the proper nutrient intake, and allow them to repair with a sufficient amount of sleep. At the end of a bulk cycle (the cycle being as long as you make it, but typically done in 4-12 weeks), you should have made some actual lean body mass gains while having gained a bit of fat in the process.
That's when you start cutting, which is largely done by changing your calorie intake. The concept of cutting is consuming fewer calories than your body's maintenance requires (so if maintenance is 2500, something like 1750-2250 as a rough guess), or by burning more calories through additional training/cardio. Either way, you do this for a period while maintaining your training routines and basic macro needs, and you should effectively burn off a good amount of body fat while keeping lean body mass loss to a minimum (LBM loss is inevitable during a cut).
Do these cycles back and forth. It's way more effective than just eating at your maintenance calorie target and lifting non-stop, provided all else you're doing is equal. You cannot effectively gain muscle and burn fat at the same time, despite what you read or hear people tell you. It's why you see a lot of people at gyms who look the same no matter how long they're at it.
