Get a actual spare tire..
Slopoke
Posts
233
Livermore, California USA
Ed
2019 Mustang GT PP1 10R80
There is a cheaper option to the AA spare. I used a spare wheel/tire assy from a 2015 Hyundai Equus. You do have to bore the center out to get it to fit. Other than that it fits our Mustangs with Brembo brakes just fine. My setup cost me $155.00 including the cost of getting a machine shop to enlarge the hub bore. The link below is to a write-up I did for mine.
https://www.mustang6g.com/forums/th...-tire-assy-for-pp1-with-brembo-brakes.136568/
tnk_2
Posts
89
New Mexico
Henry
2020 mustang GT, 401A, auto, CS, Ford SS.
I have ordered from eBay link post by bikeman315 already. I like this more same item but cost less
ice445
Posts
1,376
Salt Lake City, UT
2020 Mustang GT 6MT
He does not a PP car, so no Brembo’s
It's still the wrong diameter for the rear though, 25 and some odd inches whereas every factory wheel and tire combo measures around 27 inches. May cause issues with the non Torsen diff, I couldn't find out for sure.
tnk_2
Posts
89
New Mexico
Henry
so you are saying that would not work in the rear? I had CS, but non pp1. it's 255/40R19 all around with that CS. the ford accessories and LMR website say it will fit
ice445
Posts
1,376
Salt Lake City, UT
2020 Mustang GT 6MT
It's not that it doesnt fit, it fits everywhere without the brembo brakes. But supposedly with a limited slip diff (excluding Torsen on PP cars), too much of a diameter difference on the rear axle causes accelerated wear. Just what I have read. With the Torsen you can go like 20% difference and be fine.
tnk_2
Posts
89
New Mexico
Henry
so the one from automotive authority kit is better?
I don't know if I can cancel my order now.
ice445
Posts
1,376
Salt Lake City, UT
2020 Mustang GT 6MT
It is, but it's also way more expensive and doesn't let the trunk floor stay perfectly flat. I wouldn't worry about it too much, its a 7% difference in diameter. Just be warned that if you do have to put it on the rear to only drive it as far as you need to get to a tire shop. You could also just swap it to the front and put a good wheel on the back and be 100% fine. I'd honestly do research on your own about it, the Trak Lok is clutch based and I'm not sure the wheel speed difference that's required to cause the clutches to engage. Different diameter means different wheel speeds, but I'm not sure how 7% different diameter translates into wheel speed and how that relates to the clutch lock up. I just know that the idea disturbed me so I went with the explorer spare, but that doesn't clear the front brakes on ANY GT, which I didn't realize.
tnk_2
Posts
89
New Mexico
Henry
I would only put the spare to the front then.
thanks
FreePenguin
Posts
1,651
Ohio
Donald
17 mustang
My car had the spare kit in trunk I wasn’t charged for it
Kinda nice
Bikeman315
Posts
7,435
Myrtle Beach, SC
Ira
2019 Mustang GT/CS
This is the original Ford spare. There is absolutely no issue using it on any Mustang except those with the Brembo 6 pot fronts. It is for limited use and moderate speed. The small difference in diameter is no cause for concern. I had one on my 15’ EB with 18’ and my 19’ GT/CS with 19’s. No issues. Just do not try and do a Cannonball with it.
69mach1-395
Posts
1,564
abq, nm, usa
2016 RR GT/CS
Sold my pump kit and mini spare for a full size matching spare...no worries at all.
Zooks527
Posts
1,120
2019 KB GT, 401A, 6MT, PP1, S&S, MR, AE, B&O / 2005 Toyota Tacoma
Mine lets the floor of the trunk fit flat. Took a bit of mild encouragement with the heel of my hand in a spot or two, but it did get in once I had it level.
Another option is to let a bit of air out and keep the inflator kit behind the driver's seat to top it up if needed. Certainly not going to get anybody's legs behind me, so that space is free.
Advertisement
63 - Late Model Restoration - 1
Advertisement
