G-Loc Brakes
Bluemustang
2015 Mustang Base GT
Really! They didn't equal that bad before the track day though. Is it because they've been through a proper heat cycle?
I think so. At least that's what happened to me. If they're heated up real good they should squeal less but it's just the nature of pads like that.
tosha
Canada
Mustang GT PP1
Please don't ask me to give a logical explanation, but what helped me reduce the noise was to take the pads out, clean and re-grease everything including back of the pads where pistons touch it, both fronts and rears. But at this point you might as well just put the compatible street pads in. Plus, I am too lazy, so I've decided that I just DGAF 😄 . Windows up and exhaust in track mode solves the issue for me.
Jstang23
Jstang23
Jack
2023 Mustang GT Eruption Green
Another Update!
After a couple more days of driving the squealing has gone down quite a bit. I'm wondering if the part of the pad that got super hot just needed to wear down, but noise is back to the normal level! :like:
NeverSatisfied
Pittsburgh
2021 GT 6MT Base
Another Update!
I run the titanium shims from op. I think it helps quiet them down. They’ll get noisy, then settle down. They’ll stick to the rotors when parked overnight after rain. You take the good with the bad. I daily on R18/R12
NeverSatisfied
Pittsburgh
2021 GT 6MT Base
Not my experience with the many sets I’ve run on multiple car platforms. All pad compounds of Gloc make zero noise on track for me it’s only when using them as not intended on street they squeal and grind
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Its in their description to expect noise, and usually they do. I hope you weren’t expecting something else.
Jstang23
Jstang23
Jack
I was expecting noise, and they did when I first got them. Totally expected and acceptable. The noise however, rose like 10 levels to sounding louder than a freight train after the first track day. The change in noise level is what bothered me. I thought I may have glazed them or something. But not they they are quite again I am not worried at all!
Jstang23
Jstang23
Jack
This is my experience as well with the R10/R8 combo!
