Front strut replacement problem
petronix
Tampa
Bill
2019 Bullitt, 2002 Lincoln Blackwood, 2017 Escape
Do not heat struts with a torch! They can / will be damaged internally. In an extreme situation they could become over pressurized and explode fluid.
slime_bullet
Louisiana
Brett
2015 Mustang GT
I found that if you leave the bottom torqued down and remove the top one first works best. I've been there until I did this.
Oakley
Lee
2022 Mustang
before i just sanded down the splines enough to fit snuggly but not get stuck I took the calipers off and used a balljoint press to just scoot the bolts out.
petronix
Tampa
Bill
Interesting about the balljoint press. I was thinking to try this when I swap springs in the next couple of weeks. Good to know it works.
WItoTX
Houston
Kyle
'17 GT350
I had one side come off easy, the other, same boat, questioning my life choices, where I went so wrong, and how much I let my parents down.
I just kept hammering, and finally got it. I think I ended up removing the caliper and rotor to get a bit more leverage on the hammer.
Roger Blose
Fairfield, CT
Roger
2018 Mustang GT, 1988 Mustang GT, 2009 Lincoln MKZ
I am taking my car into a high performance shop to have the work done. I did learn that the two knuckle to strut splined bolts and nuts are one time use parts according to Ford. I just bought a fresh set to be installed next week. Once they beat on the old ones, it nice to have all new going in.
Mustangcol
Medellin, Colombia
2017 Ford Mustang GT Premium
I've done hundreds of struts and never had a splined bolt give me a problem. I thread the nut on so not to destroy the threads, turn the wheel by grabbing the rotor and turning it so its a clean shot, and hit it with a big hammer. I have the mac tools ball peen hammer set, the biggest being 48oz, a few good strikes and it flies out.
Roger Blose
Fairfield, CT
Roger
I had the struts installed by a pro shop and they knew of the splined bolts. They hit them really hard and then used my new supplied Ford OEM pieces. Not cheap but done. Now struggling with a fresh alignment and getting a straight steering wheel. It is always something but the wheel has to be straight!
kz
West Chester, OH
Mustangs & F150
There ford service bolts with smooth shank that aside from being easier to install / uninstall also allow slightly more camber adjustment.
If this shop can't align the car with a straight wheel, they have nothing to do with being Pro. This absolute fundamental thing about adjusting toe, set wheel straight and hold it and the adjust it.
CoolRod
West Coast Florida
I rented a ball joint press from a local parts store when I changed my springs. Works so much better than beating the ever loving sh*t out of the bolts. Plus, the press doesn't destroy the bolt threads.
