Front differential bolts not going in
cyclonetron
Tennessee
Patrick
2016 Mustang v6
I’m in the process of adding a new differential. I have the front bolts in fine but the rear are giving me tons of resistance. To the point where it stops and I’m afraid it will snap the bolt. What are my options? I think both threads of the bushing are stripped. Can I get a tap to make fresh threads?
ModularKid21
‘15 GT
It’s a little hard to see where the threads start so they may be boogered up. You can try and tap them and see what happens. Are the front diff bolts tightened? If so, loosen them up. The rear threads may not be aligned and that could be part of your problem
cyclonetron
cyclonetron
Tennessee
Patrick
2016 Mustang v6
It’s a little hard to see where the start so they may be boogered up. You can try and tap them and see what happens. Are the front diff bolts tightened? If so, loosen them up. The rear threads may not be aligned and that could be part of your problem
I think the bushing housing was stripped from the factory. I’m going to try tapping them first. If that works great, if not, I’ll drill out the threads and use the bolt through method. This gear swap struggle is real.
CJJon
Port Orchard
2020 Mustang GT/CS Convertible - Race Red
Remember your cutting fluid and go slow! Lots of threading in and out to clear any chips/debris.
Snapping a tap off in there would suck...
cyclonetron
cyclonetron
Tennessee
Patrick
2016 Mustang v6
Thank you for the tips. Any cutting oil you recommend?
CJJon
Port Orchard
Tap magic is generally what is available.
sk47
North Eastern TN
Jeff
Hello; Yes to this. most anytime there are several bolts to attach to an assembly I try to get all started just a little before I begin to tighten them down to the final torque spec. If you tighten down one or two the rest may not line up and even if you can get the rest forced in there can be odd stress in the assembly.
Rapid Red
Woodstock GA
Greg
Tap magic the best .....
There is a tool called a thread chaser, does not cut like a tap.
It repairs the thread, pictured is a set, the bottom, shows you can also buy single sizes.
cyclonetron
cyclonetron
Tennessee
Patrick
2016 Mustang v6
Through bolt design will be stronger And you’re already right there too.
If I go this route, will I drop the subframe and drill from the front toward the rear of the car?
cyclonetron
cyclonetron
Tennessee
Patrick
2016 Mustang v6
The only problem is I need m14x2.0 that’s an odd size and I had a hard enough time finding it in a tap. Still though, I’ll look for this.
cyclonetron
cyclonetron
Tennessee
Patrick
2016 Mustang v6
cyclonetron
cyclonetron
Tennessee
Patrick
2016 Mustang v6
I have the driveshaft to diff bolts already torqued and the rear diff bolts right. I’ll loosen the rear diff bolts after I tap the fronts. I’m really not wanting to have to take the entire pumpkin out as I struggled with it for over an hour just to get it lined up and the rears hooked in. Doing this on jack stands. But if the tapping doesn’t work I may just have to lower the entire pumpkin. Hopefully this nightmare will end soon lol!
sk47
North Eastern TN
Jeff
Hello; I know your pain. I have struggled for much more than an hour to get a few bolts in on some jobs. Even have had to make or modify tools in a few cases.
Good luck
