isedawishy
GTPPTT6REIGHTY
- Jul 21, 2015
- Fort Worth
- 2015 GT
Reconnect! There is a connection to it on the Fore hat
The line inside the tank does get hooked back up. Once you have the old out, new sitting there having unhooked the old, you'll understand.Im tackling this install this weekend, but im doing th e triple pump setup. Anyonebhave pictures of different way you installed the gauge?
As mentioned, the fuel line inside the tank gets reconnected to the fore pumps? What is this line used for? Im surprised its not being replaced.
Does anyone have a little better explanation of electrical wiring? I read that pumps 2 and 3 only come on under boost? How does that work out wiring wise?
Thank you
Their instructions for the block will show you how to wire the 2nd and 3rd pump with a hobbs switch.Yes i got fore block and their full stage 3 kit.
Here's great thread on the other forum www.svtperformance. com/forums/showthread.php?1012439-Wiring-with-Fore-fc3-controller-and-hobbs-switch remove the space to get the entire URL.Thanks! I'll read through them. They're not as good as your write up, so was doing my best to mimic your setup.
If it fits, it's fine.What do you think of this location for the fuel filter?
It fits under the plastic shielding at that spot.
Also random; but how often do we have to change the fuel filter?
Another question; Flow should "Flow" towards the front of the car right?
Only one way to find out. Put fuel through it and check for leaks.The second picture is of my fuel pumps (Triple pump system) installed. If all the connectors are snug should be ok right?
If this is the connector that plugged into the factory hat, then yes. Two smaller wires are for sending unit. Yellow/Grey == 12v+, White/Brown == Ground.The third picture this post mentions cutting 2 wires to attach to fuel pump setup in order to splice into for the fuel gauge. I circle the 2 wires I think I should cut. Please confirm?
