isedawishy
GTPPTT6REIGHTY
- Jul 21, 2015
- Fort Worth
- 2015 GT
I couldn't find any detailed install threads, so wanted to log progress as I go through the install.
I'll be installing,
You will need a couple extra things to complete the install,
I'll be installing,
- Fore level 1 return fuel system
- F1i fuel pressure regulator
- dual TI Auto F90000267 pumps
- FC2 controller
- -8 feed & return
- 88mm inline cellulose filter
- FCV checkvalve
- pressure gauge
- Highly recommend a vacuum block, especially if you plan on utilizing a Hobbs switch and/or manual boost gauge
- FC2 controller does not come with bolts or screws to mount it
- FC2 controller fuse does not come with bolts or screws to mount it
- Electrical tape for various wiring and cutting the fuel lines
- Highly recommend cable cutters to cut the fuel lines. I purchased some from Home Depot and they were only $18- LINK
- 5/16 rubber vacuum cap if retaining OEM fuel line
- E85 tester - LINK
- The goods!
- Housing with the 2 TI Auto pumps
- FC2 controller & wiring kit
- Inline filter
