ford performance new thottle body...
sirben711
Missouri
Ben
2021 Mustang Ecoboost 10R80 w/ FP Tune
ehhhhh
I think $500 would be a better price. But at least I have a backup now
sirben711
Missouri
Ben
After having it for almost a week I would like to revise one of my statements. I said that the car feels like it bogs down less in the higher gears. I need to take that statement back. Its made no difference.
The induction sound is different but I cant explain how.
Feels like it pulls slightly more.
Feels like it builds power more smoothly.
Slightly better throttle response.
Buldawg76
Alabama,USA
2020 Ecoboost Premium, 76 FXE shovel, 77 KZ1000
It does increase the available air flow into the engine so all your above observation should be accurate, just by how much is only measurable with a dyno with before and after testing results.
BD
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
"Feels like" may equal the placebo effect. Should have dyno'd before and now after.
arigr
arigr
altamonte springs fl
2020 eco pp mustang
if its that easy of a bolt-on, bolt it off and try to see what the heck the differences are... just my opinion... heck i imagine some of us here might contribute to your purchase if it saves us some money or maybe you make some some points with ford performance if we all buy it :beer: lol
metroplex
Mr. EcoBoost
Detroit, MI
Charlie
2009 Cobalt SS/TC, 2017 Fusion Sport, 2018 Explorer
The reason the 15-17 TB won't work on 18-up is that Ford switched to a digital throttle body motor controller for the 18-up Mustangs. The 19-up Ranger also shares the same TB and those went digital. The 15-17 is shared with Fusion Sport and I believe Focus RS and those are all analog.
robvas
MI
2011 GT
Any dyno results? Almost nothing to be had, HP wise, putting a bigger TB on (at least with the stock turbo and stock intake manifold) Compressed air won't care if it's going through 65mm or 70mm
metroplex
Mr. EcoBoost
Detroit, MI
Charlie
I believe in theory the only time a bigger TB would help is with a N/A engine (to a certain extent) or a pull-through forced induction setup like a Roots/Whipple blower assuming no other restrictions. The K&N style filters are only worth like a max 0.9 psi restriction which isn't much. Barometric pressure fluctuations would nearly cover that.
metroplex
Mr. EcoBoost
Detroit, MI
Charlie
I had installed the FRPP 70mm on my 2.7 about 2 years ago and then took it off in the fall when I was about to sell the car. So I re-installed it again.
Tip-in throttle response is much better than stock, but I owe that to the larger throttle blade so it acts as if you increased your throttle pedal rate (kind of like Ford's factory accelerator pedal position in sport mode vs normal drive mode).
At WOT, I didn't notice any difference. It's not worse than stock. I just don't feel it is worth the bang for the buck. I re-installed it because otherwise it'd be sitting in a corner of my closet. Same goes for my Turbosmart plumb-back diverter valve.
I looked at my notes and measurements. Stock is 63mm inlet, 61.4 mm outlet, and about 60.8mm in the central section. The FRPP 70mm is 70mm inlet, 65mm outlet (matches the intake manifold opening). 15-17 would use analog throttle body motors (Edge Sport, Fusion Sport, EcoBoost Mustang pre-2018). The newer Mustangs (18-up), Rangers, Edge ST, and Explorer ST would have the same "DigitalOutput" markings on the same throttle body motor so that is why you'd need the newer FRPP 70mm TB on newer EcoBoost Mustangs.
Vicr
Vic
BD
Agreed, and butt dyno's don't count.
metroplex
Mr. EcoBoost
Detroit, MI
Charlie
I did a lot of datalogging the summer I installed the FRPP 70mm TB and from what I recall at WOT, the max air mass didn't change and there was no sizable impact on boost (not that I was expecting any).
TeeLew
So Cal
Tim
There are plenty of 500 WHP cars on the stock TB. If a bigger throttle body gave better response, it's because it's calibrated differently, not because of what it's doing with the air. It actually hurts throttle response with respect to air flow. It may add a little power on the top end, but I wouldn't expect much.
metroplex
Mr. EcoBoost
Detroit, MI
Charlie
I suspect the TB motor/controller on the FRPP 70mm is the same as stock, so when you crack open the throttle with the pedal, it physically opens up more than stock - hence the better throttle response. Like I wrote above, it's akin to driving in Sport mode vs Normal where the factory tuning of the pedal in Sport mode makes it open more per pedal travel percentage.
At WOT I don't really feel any difference as you're not forcing more air into the engine and its not a restriction (IMHO) in the first place so no huge impact. I believe on N/A and supercharged (Whipple/Roots style and not centrifugal) you may see a benefit with a bigger TB as it is a pull-through system.
