Flex fuel tune review so far
stangman638
2019 GT350 Velocity Blue
So far, it's underwhelming. I can honestly say I don't feel much difference between stock and the flex fuel tune while running E85. I have not tried the straight E85 race tune. Ethanol content here in the winter is really about E60ish. So that will have to wait for summer. Some issues I experienced.
After initial startup in the morning, started OK in 35 degree temps, as I drove up a slight hill, car sputtered and stalled, it restarted right back up again no problem.
Sometimes on shifts, I'm guessing rather 1-3 or 3-4 gears (auto) car feels like it wants to surge and bucks for a quick second. However, doesn't happen often and when it does, it seems to be when I press on the gas, after making a complete stop, ie stop sign or traffic light.
I do know the straight E85 will be much better, however, I believed the car on E85 with a flex would have felt stronger over a straight 93 tune.I don't think it does.
Anyone else experience this?
AZ18yote
Arizona
Bryan
Here in AZ we dont have straight e85 just flex fuel which is about e54. On my flex tune it's a night and day difference from 91 octane. Pulls much harder , feels much more alive, even in 120 degree temps outside. Cold starts are more tame than 91 as well so just added bonus.
How many miles on e have you gone? What is your AFR reading? Did you try a KAM reset as well?
VikingJoe
DFW
2017 Mustang GT
My 93 race tune is a crazy difference from stock and the E85 race tune is even better. My car frikin' loves E85.
From everything I have seen, the flex tunes are not meant to be aggressive.
As for the sputtering and stalls at startup, that is normal when the car is cold. Sometimes it happens, sometimes it doesn't. But once the car is warm it is never an issue.
Bluemustang
2015 Mustang Base GT
Something doesn't sound right. It should definitely feel stronger with ethanol on the FF tune.
Zelek
Hutto, TX
2021 Mustang Mach 1
E85 race tune will have a lot stronger mid range, but both the flex and e85 tunes will have similar peak HP. It sounds like something isn't right.
stangman638
stangman638
Dunno, I think it would but then again Alex from Lund points out in a vid if you have good 93 octane in your area you may not see much difference on a flex tune.
Zelek
Hutto, TX
2021 Mustang Mach 1
Is that in regards to comparing a 93 octane tune versus running 93 octane on the flex tune? There isn't going to be much of a difference at all between those. You should feel a pretty good difference between running E85 on flex versus a straight 93 tune on 93 octane gas. Flex isn't near as aggressive as the straight E85R tune from Lund. Where you will see a lot of power is up top with flex.
I'm about to fill up on E85 for the very first time with my new flex fuel tune from Lund. I'll let you know how it goes. I've been running their 93 octane tune for well over a year so I'll be able to tell right away.
1badrz28
Woodbury, MN
The bucking is common at throttle tip in(both stock and certain tuned variances) . Add the straight e85 tune and the bucking should remove itself with the additional timing added down low.
TrevorGT
WI
race red 2015 GT
Like others said, running straight E85 on my flex tune is night and day different over 93. Yours should be also unless it’s the blend of E85 your getting.
Andy13186
I noticed a big difference between stock tune on 93 and the pbd 93 tune, but the difference between the pbd 93 tune and the e85 tune didnt seem that big to me.
scottycameron
North Central IL
2018 GTPP1 Orange Fury
My seat of the pants experience on a 1-11 dial (mine goes to 11) the stock tune is about a 4, the flex is about a 7 and the E85R is 10.5.
The flex tune is a compromise and nice bump from stock. Enjoy it for what it is and then wait for the fun to begin with the E85 tune, it's as bonkers as can be for a N/A car. E85R in track mode is a hoot...
Zelek
Hutto, TX
2021 Mustang Mach 1
I just filled up on E85 last night and loaded my flex fuel tune. All I can say is, wow.... There is a huge difference in power and the car feels different during shifts. Almost feels as if it's running cleaner.
My first WOT pull to 7700 rpm put a smile on my face. If you can't tell a difference with a flex tune and E85 in the tank, something is seriously wrong.
It took me about 15 minutes to get to 83.5% on my alch% idling and neutral rev hanging after filling up and following Lund's learn process.
StangSteve
Hawaii
2019 Velocity Blue GT Premium
How is the 93 race tune? How much different over stock and could this be a DD tune? Who did you get it from? Thanks.
