FL-2087 oil filter
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Luckily for me, I asked my local parts guy to order me a new filter housing a month ago. The housing comes with the filter as well. I just texted him, and he does have it. I'm all set for another year, but hopefully these get back in stock soon.
clavery1322
Saline, Michigan
16' GT3RS
They're just really limited in availability right now. If you do your own oil changes just order a couple from your local dealer. Some of us have been waiting a while to get them, but they'll eventually come in. I know thats not a ton of help but they are trickling in.
EDIT; they are vendor ship direct and if a dealer tells you they have to order 48 they arent lying. Just tried to order one and it got bumped to 48. 😲
gfcobra04
gfcobra04
Conroe
Gary
2000 Cobra R, 94 Lightning, 2020 GT500
I was able to get an oil filter yesterday at a local dealer. O’Reilly’s called me back and stated they can’t get any oil filters and have know idea when they will get some.
Snoopy49
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
For those of you looking for Motorcraft 5w50 motor oil, O'Reilly's Auto Parts Online, has it for $8.99 a quart and free next day shipping. They have a 15% discount code for any orders over $100. Discount code: SAVE15. 12 quarts for $91.68 plus tax.
Motorcraft Motor Oil free shipping.
Dig-It
VA
Kevin
GT500KR (0758), GT500 (N2617), GT500 (N3432)
Thanks Snoopy!
The coupon code that worked for me was “Save15”
Jmeo
You said member ;)
Massachusetts
Jaime
Got mine ordered, thanks Earl! I also had to use "Save15" for it to work. It did not like the all capitals.
Tomster
Beware of idiots
Tom
I think that I am going to use my FL2062 filters on my 350R models. If a respected member needs a 2087, let me know.
ICU812
Prestonburg,KY.
Ford Tempo, Ford Mustang,FFR,Crown vic.
I'd want to see what the oil pick up looks like, if there is enough of a restriction to crush a filter like that.
Bet dollars to donuts, the oil pickup is a clogged up mess.
Only way the pump sucks a filter closed like that is a major restriction between the filter and pick up.
The Chairman
South TX
I’ve never seen an oil filter before the pump. The pump is connected to the pickup and pushes oil through the filter.
ICU812
Prestonburg,KY.
The filter in the photo's looks like it was sucked closed.
Unless the housing oil feed is water jetting the oil straight at the middle of the filter in a fine stream, That should not happen Any photo's of the oil feed hole and location and angle to the filter media.
EF300
The Swamp, Central FL
2017 GT350, 2020 GT500 CFTP
I am thoroughly confused . What is the most up to date PN / configuration for the GT 500 filter. Is it supposed to have the metal sleeve inside the filter or is it plastic reinforced inside ?
TY
Epiphany
Global
I like to disassemble things.
Metal sleeve.
The Chairman
South TX
There is a pix out there where the filter was incorrectly installed in the housing and was somewhat crushed/twisted. It was not caused by oil flow. It was due to improper installation, and the housing was damaged inside as the filter was not properly set before installation.
Epiphany
Global
The latest filter is extremely robust. Cut one apart and you'll see how well put together they are. I give Ford credit for their efforts here.
Oakland, CA
2021 GT500
TY
Same here. Whats the part # to search for? I need my first oil change soon :(
