Anybody's guess on that one, lots of variables.At 750 rwhp which will be the first to bite the dust?
Clutch
Opg/Cs
Axles
DD application, sparingly drag
LMAO, love it... This is what I figured. Don't plan on putting anything too stick on that shit for meow, I guess clutch comes first :lol:Stock clutch will slip on dyno most likely
Axles will break with a real tire on the car first good launch
OPG's will be fine unless your spinning the #$^% out of it and banging it off the limiter
Trans will come soon unless you treat it like the glass slipper it is
Where did you buy your magnum XL? And thx for the infoClutch was the first to go on mine, then wheel hop killed my right axle shortly after that. Transmission lasted a while longer but eventually had the same fate, and then the built mt82 after that.
The only thing that has held up was the opg/cs (knock on wood) I don't shift high and have only hit the limiter a time or two.
That's funny. I actually bought the manual thinking that it would hold up better in high HP application. This was before learning about the MT82, first mustang problems :headbonk:Coulda had an auto............
LOL Just kidding good luck and may the parts not leave you stranded haha!!
Still rockin the stock clutch on my setup, still 20,000+miles deep on this bad larry.Stock clutch will slip on dyno most likely
That's good to hear, the car is only a month and a half old, with 3k miles, so maybe it will hold until Christmas :lol:Still rockin the stock clutch on my setup, still 20,000+miles deep on this bad larry.
Best thing for it? AdvanceTrac OFF. Don't launch the vehicle, and dont run a drag radial or any other sticky tire. My MPSS hook pretty nice in the heat in second gear around 50mph.
As for the power, the car made 711whp @ 7500 on a mustang dyno. Pretty sure she makes power to 8000 looking at the dyno sheet so I've been pulling to about 7800 when I get on it.
I'll get it back on a dynojet when I can.
But do replace that clutch when you can, i know im still on borrowed time.
how long have you been boosted on the stock OPG? I always felt there was more hype then reality to the OPG issue and no one wants to figure out the real issue.Clutch was the first to go on mine, then wheel hop killed my right axle shortly after that. Transmission lasted a while longer but eventually had the same fate, and then the built mt82 after that.
