First Oil Change?
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Here is my oil analysis report on my 15 GT at my first oil change
This should "clean up" on my second oil change which I will do at 8,200 miles or 1 year.
I replaced factory fill oil with Mobil 1 full synthetic 5w-20.
Looks like they used some kind of "break-in" oil as well hence the moly content. Moly is used for new engines to reduce hotspots in the metal during break-in process.
m6pwr
San Diego, CA
Richard
2015 Mustang GT Performance Pkg,Recaros
And they could have any number of organic esters for wear protection which won't show up on a uoa. Extra wear protection and moly = all the more reason to keep that factory fill in there.
daltron
Rowing All Day
Jonathan
2016 GT PP
The factor fill is just plain old Motorcraft Synthetic Blend 5w-20.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Well yes and no. Moly after break in period can act like abrasive agent accelerating engine wear.
But without doing an analysis on a virgin Motorcraft Synthetic Blend 5w-20 oil, we don't know if it's in the oil or simply in the assembling grease which they use a lot in all moving parts to avoid scoring when first time starting the engine at the factory.
m6pwr
San Diego, CA
Richard
There are many service fill oils, intended for oem's extended drain intervals, that have moly in them. Some do, some don't. http://www.pqiamerica.com/Feb2014/consolidated5w20ALL.html. Strictly speaking, moly is a friction modifier, designed to increase the lubricity of the oil, but most people treat it as a anti-wear agent, too.
I don't know if any of us can say with any certainty that the factory fill is this or that oil. I agree that it is probably the MC syn blend (and I can't recall seeing a voa of that oil so I don't know if it has moly in it or not, although the PQIA seems to indicate it does).
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
You'll get 1,000 different opinions on both those questions.
Here is your first opinion: AMSOIL SS 5w-20 or 5w-30 and their EO filter DIY or taken to a trusted dealer/mechanic.
This.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I did my first change at 1,500 and the next at 10,000 (at least 2/3 of those 8,500 miles were highway though, so I'd have changed sooner if I was driving my current cycle of about 50/50, 60/40 city/highway). The Blackstone analysis of my 10,000 mile oil was incredibly good, almost no metals or undesireables at all and very good TBN (4.7). I use Pennzoil Ultra Platinum 5W-20. I just did my most recent change at 19,500 and have sent a sample of that in for analysis as well, since my drive cycle changed significantly after 15,000.
Got my most recent analysis on Pennzoil Ultra Platinum 5W-20 that had 9,500 miles on it. All good things.
m6pwr
San Diego, CA
Richard
That's an outstanding uoa. With these kinds of results, i can't understand why some folks are so afraid of 5w20. It would appear Ford knows what they're doing.
BmacIL
Enginerd
Naperville, IL
Agreed. It matters which 5W-20, certainly, but don't be scared off by it. The engine is designed around it. I might go up to 5W-30 for tracking it, but that's it. I do not baby the engine at all once it's up to temp. I let it build up some heat before taking off, about 20-30 seconds of idling in this colder weather, and nothing over 3000 rpm (I try for under 2500) till CHT is over 180 F.
WKT
I Bleed FORD Blue!
Hilton Head Island SC
Keith
2018 GT350 Lead Foot Grey
I did my first oil change at 1,000 miles, used Motorcraft 5w20 & FL500 oil filter, I just did the second oil change today at 5,000 miles and I switched to Royal Purple 5w20 full synthetic. I will probably change it every 5,000 miles from here on out.
BmacIL
Enginerd
Naperville, IL
Do a UOA, save yourself some money (probably). It's $20 and they can tell you how your engine and oil are doing. See above ^^. For good synthetic, extending your interval to 8-10k miles vs 5k miles would save a good chunk of change after a few years, considering it takes 8 quarts.
WKT
I Bleed FORD Blue!
Keith
Tell me about it! The local parts store lets me have the Royal Purple at good price $7.25 a quart, but at 8 quarts thats still $58 plus the oil filter.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Depending how much you drive I would just change it once a year.
BmacIL
Enginerd
Naperville, IL
Yep. The pennzoil ultra platinum is very pricey as well at $40 for 5 qts. The fact that I can go to 10,000+ miles takes the edge off of that price. It's amazing oil, though.
WKT
I Bleed FORD Blue!
Keith
Thats what it will end up being, about 5000-6000 miles per year.
