Factory Piston Pin height
Oakley
Lee
2022 Mustang
i don't have the measurements but it should definitely be below the head and valves.
if its above those you got a real problem.
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
If the point is to boost the motor, is the 0.2L really worth the effort?
Take a look at FFRE where they keep the engine at 5.0L to have a stronger cylinder wall, they just chuck in a ton of boost haha. Their 5.0L on bretts car has gone low 6s 1/4 mile. I think they are turning 9k+ maybe even over 10k rpm.
For an engine making a lot less than 2000+hp it would probably be just fine to have the cylinder walls thinner to get the 5.2L. Just not sure if it's worth it to increase the stroke to get another .2L when you could just add a little more boost.
This setup: https://rpgracingengines.com/product/rpg-max-effort-n-a-5-5l-short-block/
Would be a sick N/A motor.
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
It would actually be a bit over .4 total and on the low end side it probably would be worth it. Not using a factory block, I’ll be using the Bear Block.
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
The compression is way to high for what I’d use it for but I bet at 14:1 that thing make 670+ to the wheels. We did a 13.1 sbc 377 back in the 90’s and that thing made over 700
tdstuart
Arizona
Triston
Ya they say it can do over 700whp with the right heads, cams, intake, etc.
Way too high compression for boost though.
tdstuart
Arizona
Triston
So would it be 5.4 or 5.6 (5.2 block + 0.4 stroke) total?
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
So the 5.2 and 5.0 use the same 3.65 stroke. The only difference is the bore. The 5.2 has a 3.7 bore and the 5.0 has a 3.6x bore. 3.7 is a max bore on these blocks due to the bore spacing. That’s why the only way to gains and cubes is to increase the stroke. That motor uses a 3.9 stroke with a 5.85 rode with a 3.7 bore to get to 5.5L or 335 CI. I don’t like the idea of having the piston above the deck and having to run an extra thick head gasket with boost. I’d rather lose 4 cid and keep the piston slightly below the deck and make it up with boost 🤷🏼‍♂️ so to answer your question it would be going from a 5.0 to a 5.43 or 331 CI with a 3.7 bore and 3.84 stroke. So a total increase of .43 CI for an extra 25 CI with much more low end torque due to the stroke. A Centri would love this motor.
tdstuart
Arizona
Triston
I fantasized about 5.4 badges on the fenders….
I looked into doing a stroker when first building my motor and had this same thought. Couldn't find any though haha would need to get some custom made
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Y'all are worried about piston speed rod ratio ect..... I'm just going to throw this out there. We were building 4-5/8ths inch stroke twin cam HD's for YEARS. Spinning the max effort one's to 7500-8000 RPM
The pistons, pins and rods are beyond good.
