Factory Piston Pin height
GregO
Illinois
S550 GTPP
I’ve been away from average piston speed for a while. Without doing a deep dive what are current reliable piston speed numbers ?
Materials continue to improve over time so that number should continue to rise.
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
In my heart with good hd rods and 3.84 stroke you could run this combo with a max of 25 to 28 lbs of boost up to 7800 rpm and it live a long time. You would need l19 or 625 main bolts and rod cap bolts and I’d do steel main caps…..but I think for a street strip build it would rip!!!
engineermike
La
2018 GTPP A10
Piston velocity at tdc is 0! Acceleration is quite high though…
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
GregO
Illinois
S550 GTPP
No we were running these in production bikes. No room to lengthen the cylinders. So shorter than stock rods.
So are we talking 7.xx”
What is the stock length you’re referring to.
K4fxd
NKY
7.6
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
That’s still a good rod ratio. In modern times the idea of 1.8 has been pushed aside due to material science and it’s been proven in most cases a 1.6ish ratio makes better torque. This combo and an LS7 are in the 1.5x range which is really on the edge of my comfort zone.
K4fxd
NKY
Yes, but piston speed is off the charts. All my engine programs say not to spin higher than 6000. These live in the 8000 range. Piston tech has come a long way.
GregO
Illinois
S550 GTPP
The days of Smokey’s “Use the longest damn rod as possible” have changed a lot.
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
This is very true! 496 bbc by all accounts has a horrible rod ratio (1.37) but we spin them to 6800k and 7xx hp in big compression (14.1 to 15.1) race trim back in the day 🤷🏼‍♂️
