Factory 19 Staggered Tire Size
reju212
Evansville, IN
2017 Mustang GT
What is the largest tire you can put on the factory 19"staggered rims? I have 255 on front, and 275 on the rear. Just kinda curious.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Well, theres how much you can push it and then theres how much you should push it, and then theres why you would or wouldnt, which depends on your specific tire of choice and your goals.
I’ve put a 285 on the front 9” before, but you probably shouldnt for most tires. The tire I used had very stiff sidewalls
I would guess somebody has squeezed a 295 or even a 305 on the rear, but again, its not usually a win-win situation.
The stock wheels are very heavy. If you want to run a wider tire, the best thing to do is figure out how wide you want to run and then go buy a lighter stronger wheel which will work the best for that tire. You dont have to pay a ton for wheels. SVE has some great options in 10” square or 10/11” for like 1200, and less after you resell your stock wheels.
shogun32
Northern VA
you can run 275 square. I personally would run 255 square or 265 square.
Otherwise just buy proper wheels already.
GrabberBargeCaptain
CA
Just stick with the 255s, handling is mushy enough as it is
