Running same tire size on staggered setup
Lowkeyslow
California
David
2019 Mustang GT
Do any of you guys run the same tire size all around on a staggered setup? I’m wanting to save a couple bucks and get a set of 4 of the same tires. My wheel specs are 20x10 +38 & 20x11 +22 And I’m wanting to get 275/35/20 all around. Any good cheap tire recommendations? Maybe somewhere between lionhart Lh5s and nitto nt555s. Thanks
shogun32
Northern VA
I hope you meant to type '52'?
I would go minimum 285 for starters.
any reason for going 'cheap'? are you just wanting to burn them off in a cloud of smoke? I would instead get 2x more of the 10" wide and if you're looking for 'phat' look slap a 5mm spacer on the rears. Now you have a rotatable setup and you can buy cheap tires in mass quantities.
Bluemustang
2015 Mustang Base GT
Cheap tires... never a good plan dude. Everything about the car gets worse with cheap tires.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Nitto says the 275/35 will fit on an 11" wheel, so it will fit. In general I wouldn't hesitate to run a stretched rear tire... except its a Nitto 555, which aren't great. Try the Firestone Indy 500 for a cheaper tire.
EFI
Masshole central
5.Br0
How much more could a 305 tire be compared to a 275?
After spending probably close to $2000 on the wheel and tire setup, is another $50 to run the proper size tire in the rear going to make or break you?
m3incorp
Georgia/Colorado
James
I'm waiting to see that +22 offset on the rear. Why are there so many people lately inquiring about cheap tires???? Heck if you want cheap, just do a retread and see how that works out.
