Ordered my SVE SP2 staggered set tonight! Will order the Michelins when it gets closer to spring (hoping for fresher rubber). Thanks again!That tire will be a somewhat smaller o'all diameter and create fender gap. Unless you are dropping the backend 1" or more it is noticeable. You also have significant effects to the stability control programming and speedo (unless you can change your tire sizes/aspect ratio in your program/tune).
What tires are you getting? A mix of PSS+PS4S or both of the same kind.Ordered my SVE SP2 staggered set tonight! Will order the Michelins when it gets closer to spring (hoping for fresher rubber). Thanks again!
Still deciding... I did email Michelin and they advised against mixing the PSS and PS4S. Although they also said they can't advise on tires that are not stock sizes for my vehicle. Was strange...What tires are you getting? A mix of PSS+PS4S or both of the same kind.
My car is stock ride height, so I'm not sure I want the 325/30 tire as it is a bit shorter.
I got the same combo 2 weeks ago, no problems at all till now.Yea thats a big reduction, just at 1". If you are set for 305s out back, I would go with the 285/35/19 PS4S with the PSS 305/35/19 out back.
Basically my twin.I was originally going to do the PS4S and PSS combo....but ended up going with the Nitto 555RII drag radials for the rear since I just put a Whipple on the car. So I was looking for the Nitto G2s for the front to somewhat match. Nope, they are on national backorder for 285/35/19. Talked to Nitto direct and they could not even give me an ETA.
My local discount tire tried for 3 weeks to snag a set from another store, but it never materialized. They ended up giving me the Michelin PS4S for the front at the same price as the G2s. All good by me! Put them on the car today. LOVE IT!!
