Evap Leak.
poneyexp
georgia
Rene
2015 Gt premium
Good evening; getting an evap leak message, 2015 mustang gt any common areas of possible leaks. Thank you
sk47
North Eastern TN
Jeff
Hello; On my 2004 chevy pickup I get a similar code every few years. Turned out to be the gas cap. I have an aftermarket locking cap and was able to replace the O ring eventually. Before that I was able to clean the cap and rub some Vaseline on the gasket which sealed things up.
That said there are purge valves and plumbing as part of the fuel storage systems of modern cars. This is supposed to prevent fuel vapors from escaping into the air. This system can also leak.
A caution when filling up the gas tank. I have been told it is now wise to overfill the gas tank after the fill nozzle clicks off.
SheepDog
Colorado
Dax
How is this relevant to a vehicle that doesn't have a gas cap?
@poneyexp what code are you getting?
sk47
North Eastern TN
Jeff
Hello; I see these capless fill ports on some cars. I do not know if they are foolproof. If they do happen to be foolproof such will eliminate a possible leak.
ORRadtech
Atlanta, Georgia
The evaporative purge valve is prone to failure as is the charcoal canister vent valve. There is also the canister itself and lines from the front to the back. Ford's capless filler can leak as well.
A smoke test will show if the system is leaking to the atmosphere. If the purge valve is leaking internally you can test to see if it passes vacuum when the electrical connector is disconnected.
Just hope the issue isn't on the tank, I believe the subframe has to come down to access the top of the fuel tank.
IPOGT
Alan
Hello back. I wouldn’t trust it either. Odds are someone will build a better fool certain to defeat it.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
What code
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
^^^ Yes this is the most common but other part failures can cause this. The code itself can also be a fuel tank vacuum issue.
If so, fuel tank pressure sensor is a bitch to change. Also check your fuel flap.
Once you make your part change or find any leak in the evap system clear the code using an off the shelf OBD-II scanner.
Now this is where the fun starts…
If you have to Smog your car you’re gonna need to get all your monitors to come back online. This will require several drive cycles which can be found using the search tool. The hardest to come back online are the 02 and 02 Heater monitors.
69mach1-395
central nm, usa
2016 RR GT/CS
Still have my code...staying tuned here.
mookieit
tampa
john
mustang 2015 v6
When I did a smoke test, smoke was coming out of the evap canister in the rear.
After replacing it, codes were gone
