Engine/Transmission Plate Noise FIX!
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
Thanks!
DCShelby
DC
Robert
Plate ordered and on the way.
MustangNY
NYC
2015 mustang gt and 2017 Shelby GT350
I dont understand how there is no TSB yet for this when Ford clearly changed the part number and now its coated in rubber.
DCShelby
DC
Robert
I’m taking it in Tuesday next week. The regional rep wants to chat with me. The service writer told him that they were unable to replicate it. So I will take him on a 30 minute drive in the heat till the fluttering starts. But yes, the fact that the new part is entirely coated in a rubber material shows they know the problem exists.
Tomster
Beware of idiots
Tom
I'd just get some dynamat. That's my plan.
Frank.Herbst
Denver, CO
Frank
2019 GT350
Ford has recognized that it is a problem. The latest revision of it is coated in a black rubberized substance.
Can you post the engineering number that is stamped on the plate. Its viewable when looking up at the side of the plate facing the back of the oil pan. Of you don't have access to looking up can you post the part number on your work order? My new plate is not rubber coated.
Thanks.
Droopy1592
Atlanta
Damien
2017 GT350
That isn't the latest revision. The one the dealer put on the car during my engine replacement is completely coated in the black rubberized substance.
Dynamat works best so your drivetrain doesn't have to be disassembled to replace it.
anyone got the part number for this
Tomster
Beware of idiots
Tom
fsujmm
2004 Mach 1 (Sold), 2017 Gt350
Can anyone post a picture of their plate with dynomat on it? Im confused how I would go about doing this at home?
DCShelby
DC
Robert
There is a thread here that shows it
Shift
CA
a Ford
My rattle got much worse after they replaced the clutch. Might have been possible for them to replace the plate with the new version, but no ETA on parts availability, and I just wanted the car out of the dealership already.
Had a chance to finally apply some dynamat to it, and it's reduced the rattle by about 85%, which is perfectly fine with me. Even with everything bolted properly, you can still flex the plate if you touch it at the very bottom with just your finger, so I'm not surprised I haven't completely eliminated the rattle can noise. Just an inherent flaw in the design.
NoXiDe
GA
GT350
Which is the dynamat you used? I attached lead tape to it and it somewhat helped. Did you just slap whatever you could inside of it by using your finger or did you attach it to the outside?
Shift
CA
a Ford
I went with the thinner version, I figured I could always layer it if I had enough room.
https://www.walmart.com/ip/Dynamat-...m-msg-id=5dab0a66-3384-47ab-b22b-5fc9f0328d66
This was way more than I needed. The main piece that I cut out was 7"x2" applied right to the center of it, and I applied it with just my finger. Since the butyl is very malleable, I made sure to smooth/crush the butyl along the edges. There was a small bit of area that you could apply a small triangular piece right above the bottom left and right bolts, so I put a piece there.
Basically just stuck it on wherever I could. I ended up doubling up on the 7"x2" piece. Unless you've got fat fingers, you can fit your fingers in there fine. I could easily throw on a couple more layers, but I felt it was sufficient. If I'm ever under the car again, I may just do that. Hope this helps.
NoXiDe
GA
GT350
cool, i did this with the lead tape suggested from another member but it's still there so ill try this next. ill just slap it over the lead tape i assume it's really sticky like VHD stuff
