Engine light on
500PLUS
Berkshire
2018 GT
I have 2018 GT 11.5 k miles U.K. car
Occasionally the engine light comes on
For instance today in a drive in rain
Goes off after next drive
Car seems fine but very annoying. Any thoughts
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Get a code scanner. Could be a million different things. If you get a code scanner you will see what issue is popping up.
I think some auto parts stores will do it for free.
Could be a lot of things (misfire, overheating, bad sensors, etc.). Go get the codes checked and you will narrow down your issue!
Twin Turbo
Super Moderator
Moderator
England
Paul
Mustang '05 GT
Just Google ODBII scanner.......Ebay, Amazon. Or just take it to a Ford dealer and they'll do it.
Try getting the DTC using either of these methods based on which dash cluster is in the vehicle. You don't need a code scanner to grab codes, you can do it via the Engineer Test Mode:
If you have a 2015-2020+ with the ANALOG gauge cluster, you should be able to enter the “Engineer Test Mode”.
Follow this link:
https://www.mustang6g.com/forums/threads/engineering-test-mode.27581/
If you you have a 2018-2020+ with the DIGITAL cluster, you should be able to access the same test mode found here:
https://www.mustang6g.com/forums/th...n-18-digital-dash-old-way-doesnt-work.115231/
