Can I Adjust MPG on 18+ Digital Dash? (old way doesn't work)
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
Dusten
Conway, Wa
Dusten
2018 Ford Mustang, 2001 Ford Lightning, 1968 Ford Mustang
How many tanks did you drive to get an average? One tank alone will be very inaccurate.
Mine is off every tank. Consistently 1.5-2
Deleted member 33561
Guest
I got my 2018 to work before. Here is how I did it:
Turn on the key but do not start the car. (press "Start button")
Put the display in the mode where it is blank.
Hold the "OK" key and start the car.
When the "Engineering Test Mode" shows up release the "OK" button.
Use the up/down arrows until the AFE Bias shows up.
Press the "OK" key and then use the up/down buttons to adjust the Bias.
When you have what you want then hit the "OK" button to save it and you're done.
That is what I remember. If it doesn't work, don't shoot me. I'm just the messenger.
Stangnut
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
And you have the digital dash?
Guest
Yes I have the digital dash. My car is a GT premium with the premium package. It has the performance package with active exhaust. I don't know if there are options that affect this setup. But it works on my car. As you adjust the bias you can actually see your miles per gallon change at the same time just above that. So if you happen to have a typical MPG error in your dash at this time and you have calculated the correct value you can adjust the bias until it reads the correct value
Stangnut
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
Thanks, 7thStreetJim. I'll give it a try!
TicTocTach
DFWTX
Clair
2018 EBPP
This is awesome info! I've been tracking my mileage since I got the car - a habit I got from driving a Honda Fit for the last 11 years and the Scan Gauge II I used in that car would calculate mileage to within a very small percent error. It was really nice having a lot of confidence in how much fuel was in the tank AND how far it could take me in a pinch. The EBPP has been generally improving the error since the first tank, and is around 5-6% now with a downward trend. I'd really like to cut that error in half and tweak it again later if needed.
Thanks!
TicTocTach
DFWTX
Clair
2018 EBPP
Dusten
Conway, Wa
Dusten
Adjusted mine. I'll see how it goes
RichBrew
GA
Scott
2019 Velocity Blue EBPP
Excuse me a minute while i bookmark this post.
Seriously, I've been trying to figure out how to get into the engineering test mode on the digital cluster since i got my '19 4 months ago! Thanks for this!
TicTocTach
DFWTX
Clair
2018 EBPP
Adjusted mine as described above and it worked perfectly. Just filled the tank tonight, so we'll see how the new 6% lower calculation goes.
Great info for the 2018/19 owners who have the digital cluster and have been seeking how to enter the “Engineering Mode” !
GT Pony
Pacific NW
i'm surprised there isn't a YouTube video showing how to.
