ice445
- Apr 13, 2020
- Salt Lake City, UT
- Ryan
- 2020 Mustang GT 6MT
Thank you for coming back and posting the solution, not many people do.For anyone searching in the future the solution for me at least was to update the VIN’s in the ABS and RCM modules to match those from the PCM and BCM, then do a PCM module initialization. After this the Starter Block PID’s in the PCM reset to “no” and the PATSENABL PID reset from “disabled” to “enabled”. Engine fired right up afterwards.
I was pretty sure there would be a DTC when the PATS disabled the vehicle but that wasn’t the case. So definitely check the PATSENABL PID in the PCM if you suspect PATS is interfering with the start sequence, regardless of DTC’s.
