Engine Immobilizer Lock - PATS?
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
For anyone searching in the future the solution for me at least was to update the VIN’s in the ABS and RCM modules to match those from the PCM and BCM, then do a PCM module initialization. After this the Starter Block PID’s in the PCM reset to “no” and the PATSENABL PID reset from “disabled” to “enabled”. Engine fired right up afterwards.
I was pretty sure there would be a DTC when the PATS disabled the vehicle but that wasn’t the case. So definitely check the PATSENABL PID in the PCM if you suspect PATS is interfering with the start sequence, regardless of DTC’s.
Thank you for coming back and posting the solution, not many people do.
Scootsmcgreggor
CA
2016 Ecoboost turned GT
Of course. The number of dead end threads I found while researching this issue was immense so I wanted to be sure mine wasn't one of them. Hopefully this helps someone in the future.
Excellent update and information for future reference - thanks!
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
This out to be a sticky. Too many people change or charge the battery and it’s still failing, when it’s the immobilizer system.
Scootsmcgreggor
CA
Also I realize I didn’t state that all the module programming I listed was done with Forscan.
MIKE MOORE
HARRISONVILLE, MO
MIKE
1956 OLDS 88
I know this is an old thread, but I wanted to say thanks for posting the fix. I'm fighting a similar issue, no crank, no start when pushing the button. Waiting on my scan tool to get here and I'm going to try this before replacing any modules.
Scootsmcgreggor
CA
Good luck hope it works for you, please post up your results as well. I’ve wondered if this was just a solution for my scenario or one that can work for a number of situations.
IndyDog
Western CT
2015 Mustang GT 6 Speed Manual
Glad I found this thread, I'm having the same problems and nobody can find a solution, it's almost driven me to get rid of the car and move on to something else. A car that wont start is obviously garbage to me and anyone else.
Unfortunately the solution posted by Scootsmcgreggor might as well be martian to me so I need to find a competent mechanic to look into this fix
Does anyone know a mechanic/dealer in Fairfield County CT I could contact? Neither of my local dealers have a good rep and I'm not too keen about taking it there.
Thanks in advance.
