Engine failure
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
A head gasket failure doesn’t always allow coolant to contaminate the oil. Depends where the gasket blows out.
Agreed, often times it’s the oil in the coolant since cylinder pressure is much higher than cooling system pressure.
vaeevictiss
VA
Sean
2021 Mustang GT Premium PP1
Your flag is hung wrong too. Stars on the left.
Traffic22
SF Bay Area
Chuck
2018 F-150 Raptor, 2011 Ford CV Lemons Race Car
You’re also going to want to inspect the cylinder walls. Guessing as a guy who has built this kind of quality engine, you already know this, but just in case you don’t…..coolant intrusion into the combustion chamber can cause scoring of the cylinder walls.
I would hate to see you fix everything, button it all back up only to have blow by and misfires because the rings are now not sealing to the scored cylinder wall.
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
The cylinder wall has some interesting patterns in it, appears to be lots of oil consumed in that cylinder. Trying to follow, you used a Gen 3 block and swapped the rotating assembly into that block?
It almost appears that the expander ring has decided to leave the confines of the piston.
geep81
Cleveland OH
2020 GT Premium
furdfan2018
AZ
Mustang
At 260 you probably warped both heads and they now cannot sit flat on the block.
Have both of them surfaced, new gaskets, throw it all back together.
Mad1186
Mad1186
South Carolina
tripleseven-na.com
Kevin
2016 Mustang GT Premium Ruby Red
You are telling me! I hope all is alright, i check on all of it Wednesday when i am back home again so far i drained the oil and it is chocky milk indeed.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Mad1186
Mad1186
South Carolina
tripleseven-na.com
Kevin
So i put a new gen 3 short block in the car, that was just the old motor sitting on a pallet in my garage right now.
luca1290
Italy
Luca
Mustang GT, MB A250 4Matic W177, Mazda MX-5 ND, Ford S-Max 2nd series, Lancia Y
Ouch, then there is a substantial quantity of coolant in the oil. I guess you won an extensive rebuild of the engine.
The thing is, don't you have a warranty on it? If the engine was correctly reworked in the first place this shouldn't have happened.
It's either their incompetence, you being extremely unlucky or you abuse your engines past what they are meant to endure because one catastrophic failure can happen, twice you are becoming a statistic....
Don't mean to bash on you but have at least a conversation with who worked on the car.
