Ecoboost vs Ecoboost hpp
Georgia
N/A
Hey, I can either get a regular Ecoboost premium or Ecoboost premium with hpp. My brother has a 21 Ecoboost premium and the car is very smooth. I really like to drive it and it drives comfortably.
My question is does the hpp drive harsh or firm? It has bigger rear sway bars and different chassis tuning and heavy-duty front springs.
I just want to know if it’s going to be noticeably different when daily driving the car?
KingKona
Virginia
Shlomo
2019 GT
Yes, especially if it has the EcoBoost handling package. That's the whole point to it.
IMO, since you're asking the question, the HPP isn't the car for you. Go for the regular EB.
Son of SVO
Haverhill, MA
Peter
2020 HPP Ecoboost premium coupe
No question here. Go with the HPP. Even without the handling pack you get the tuned for Mustang Focus RS engine, GT brakes and a good selection of GT pp1 parts. Oh, and HPP specific wheels and appearance parts.
KingKona
Virginia
Shlomo
2019 GT
That's absolutely NOT what the OP is asking about. They're not interested in your opinion of the HPP based on what you want in a car.
The question was; "...does the hpp drive harsh or firm?"
The answer is yes. Yes it rides firm. And at times could be considered "harsh".
Son of SVO
Haverhill, MA
Peter
YES, it does ride firmly. Apologies for my editorial content. As Mustang owners aren't we ALL just a little fond of our particular choices?
steve0s550
AZ
STEVE
2020 HPP 2.3 Mustang
I Dow find the HPP AE at low rpm drone annoying may need to swap a standard exhaust and splice the quad tips in.
Maybe add in a resonator since it comes from factory without one. Or quite mode?
steve0s550
AZ
STEVE
In quiet mode all the time. Will look into resonator. It's just low rpm when rolling. At a standstill it's fine.
Have sound deadening all over the truck pan as well. I think is coming in through the rear seat back
I don't notice any drone with my AE except in drag or track mode at low rpms. All the other modes seem fine and I'm even running a NX2 and 3" CVF catted DP. But yeah adding in a resonator would be way cheaper than new exhaust and splicing in your AE tips/valves.
shogun32
Northern VA
no difference worth noting. The HPP comes with the same 'FP street' dampers that come on the GT/PP1. It's a touch more damping but nothing remotely coming close to NVH increase. The suspension in both trims is quite lacking so if you want good handling you'll be swapping at least dampers out with eg. Bilstein to get proper damping behavior.
spin the motor over 2000 or better yet 2500 all the time. Since I can't hear the exhaust at all on my car (no Active Exhaust) so I'm putting in a Y pipe and GT 4-output exhaust.
BlueHPP
Lloyd
2020 Mustang HPP/HP 6MT, 2013 Boxster S, 2026 Chevy Equinox EV
As the owner of a 2020 HPP/HP car I have tried to find the differences between the base and HPP ecoboosts. Here is what I have found
1FA6P8TH8L51880911FA6P8TD8L5143XXXHandling packageSource
RegularHPP
EngineLR3E- 6007-CALR3E- 6007-AAFord Service CD
Cylinder headEJ7Z-6049Asays high strength no part # diffTech Specs
Head GasketEJ7Z-6051-CEJ7Z-6051-EOnline part #s
BlockLR3Z-6010AHigh tensile liners-no part # diffTech specs /Hot Rod
Piston RingsImproved- no part # differenceTech Specs ?Hot Rod
Turbocharger57 or 60 mm 18 psi63 mm impeller/ 22 lbs boost
springs?Stiffer frontFord Engr video
Front sway bar/Rear bar32 mm front/20 rear32 mmm front X 21.7 mm rear33.3 mm Front/ 24 mm rearTech specs
Front brakes320 X 30 vented single piston352 mm X 32 vented 4 piston caliperImproved padsTech specs
Rear Brakes320 X30 solid single piston330 X 25 vented single pistonTech specs
active exhaustOptionalStdStdTech specs
Wheels18 X 8/ 19 x 8.519 x 9.019 X 9.5Tech specs
radiatorRAD 129Larger RAD 205 20% more capacityTech specs/ Mishimoto
ECM
Differential3.31 ltd slip3.55 ltd slip3.55 TorsenTech specs
Shock absorbersMagnaride electronicTech specs
Weight90 lbs lighter-354236323632Tech specs
Things to remember:
Tech specs are not always right.
After April 2021 the Handling package cars got the six piston Brembo brakes with 15 inch rotors.
If there is really a difference what is the part number for the different part? I cannot find a different part number for the head or block.
Overall I really like the car for the value. I have checked on the weight difference between a GT and the HPP. Base GT is only 73 pounds heavier but the Bullitt is 218 pounds heavier than a 6MT HPP/HP car. So a PP2 car I would expect to be about 170 with all of the upgraded parts.
