Using stock PP pads & calipers?AP racing is going to have two piece brake rotors for the stock size for $1200, ~20 less lbs of unsprung weight.
Also, I am working with Apex Wheels to get some EC-7's in 18" sizes for track use. Will update you on fitments when I can.
Just checked out those wheels. Looks like a pretty good price. I see they already make 18x10 +43. Hopefully they'll make the same size but +40. I know those should fit the s550 well.AP racing is going to have two piece brake rotors for the stock size for $1200, ~20 less lbs of unsprung weight.
I could be wrong but isnt the v6 just a few more lbs more that ecoboost? Also, didnt someone post a pic of a v6 or ecoboost on a weight station?For the Ecoboost you will need springs made just for the Ecoboost. The weight over the front axle is less than the v6/v8. I went with the Eibach sportlines and absolutely love the handling now. it corners much better than I expected. But it's a even drop 1" front and back. On the v6/v8 it lowers the front more than the rear.
You are correct. In fact with the manual trans, the ecoboost is heavier!I could be wrong but isnt the v6 just a few more lbs more that ecoboost? Also, didnt someone post a pic of a v6 or ecoboost on a weight station?
I could be wrong....
:cheers:
I'm still trying to figure that one out. But, going to a 13-15lb billet steel flywheel and lighter stronger clutch should help make up for that ~20lb difference. Ultralight flywheels aren't so good to turbo motors, but the stock one is outrageously heavy.You are correct. In fact with the manual trans, the ecoboost is heavier!
What's turbo got to do w/ it?Ultralight flywheels aren't so good to turbo motors
I did a quick google search because I was curious as well. From what I gather a heavier flywheel puts more load on the engine, and more load on the engine decreases spool time.What's turbo got to do w/ it?
Good call. Read up on the issue a bit. Would like to see data to substantiate a turbo acts noticeably different. I'm skeptical.I did a quick google search because I was curious as well. From what I gather a heavier flywheel puts more load on the engine, and more load on the engine decreases spool time.
Seems you want lighter to increase engine response but not too light because you'll decrease turbo response.
Don't know for sure, but with more torque and fewer power strokes per engine revolution, a turbo four compareed to a N/A V6 is likely to have greater torsional vibration of the crankshaft. Therefore the heavier flywheel would help offset/absorb some of that.Good call. Read up on the issue a bit. Would like to see data to substantiate a turbo acts noticeably different. I'm skeptical.
