Ebay/Amazon TPMS Sensor
spedy7
Arizona
James
1966 Mustang coupe, 2023 GT
Might go to Rock Auto for a set for my other wheels, $25 a sensor is cheap!
For programming sensors to the car a relearn process has to be done, "tire training" as Ford calls it. Start off with the ignition on engine off, hit the brake once, cycle the ignition 3 times, hit the brake again, cycle the ignition 3 times, horn should honk. You'll need a tool like this to trigger each sensor LF, RF, RR, LR. It'll have to be done anytime you swap wheel sets since no more than 4 sensors are stored.
TonyNJ
Northern NJ
www.instagram.com
Tony
shogun32
Northern VA
No joke? I can buy these for my 18gt, and no programming needed? Just install and go?
yup. I have 3 sets of wheels I swap without a care in the world. NEVER have to re-train the car with the ^^^ referenced magic incantation or any 'tool/fob'. It just works.
Whatever you do do NOT buy the cheap-sh*t TPMS from American Muscle or CJ Pony. And if your Ebay el-cheapo units have an 'X' in magic marker on the body, it's a damn good chance they are dead. And the seller just ripped you off.
m3incorp
Georgia/Colorado
James
I would maybe go to Discount Tire/America's Tire and have them try to program with their programmers.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Yeah I took a gamble and prepared for the worst. So I wasn’t let down too bad since expectations were low. I was on a personal mission on trying to get wheel, tires, and tpms under 1k so I tried to save wherever I could.
i have an aftermarket set (came with the wheels) that won’t auto-sync to the car on their own. That’s ok the Ford sync tool is pretty cheap on eBay and works to get them to connect. Once connected they stay that way.
i actually kindof like using the tool after I switch wheels (which I do a lot) because I don’t have to wait and wonder if the tire pressures are correct to the wheels I’m using.
MD18EcoStang
MD
2018 Mustang Ecoboost
Yep. Bought these a few months ago. No reprogramming needed. They just work.
https://www.ebay.com/itm/4-NEW-OEM-...RS-2015-2018-F-150-EDGE-MUSTANG-/171889613623
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
I bought a set from Amazon when getting new wheels for my '15. Couldn't get them to work even with the tool. Turned out one of the four was bad. After replacing the bad one they synced right up. A year later I put the same wheels on my '19 and they worked fine. Not sure if it was just bad luck or if the odds are greater of getting a bad one from Amazon or eBay.
EgoBoost
9/11 Never Forget
2024 Black PP GT 6 SPEED
I use tirerack. Cheap and works without any relearn device.
