E85 without a tune
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
Well there are 2 gas station that my buddy uses that have tested with high E85 in the ball part of 80 to 84%. I also found an Orion gas station that has E90 which states that its 90% Ethanol. I would love to try it out but once I'm tuned. I'm waiting for my 2021 GT to come.
What tune are you using?
beefcake
Bethel
2018 Ford Mustang
If you're wanting to get the full benefits of E85 I would recommend going with a Lund tune. Then you'll be able to run a full tank of E85 and not have to worry about making sure you're getting the mixture correct or getting a few bad gallons or E85.
Feel Free to DM me or call with any questions.
Terry "Beefcake" Reeves
Office - 855-TBR-RACE - Cell 513-478-1965
Owner Team Beefcake - 20+ Years Experience
Deal Directly with the boss, no pushy sales guys!!!!!!!
https://www.beefcakeracing.com - Your Forced Induction Specialists
#beefcakeracing #teambeefcake
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
The duty cycle on the injectors are probably having a mental breakdown. There's a reason why FORD says max E15. Gen 2/3 coyote makes no difference. actually gen 3 probably cause if it running only on the PFI or DI side the injectors are much smaller than the Gen 2's.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
The duty cycle is just fine. The ECM can compensate for E30 without any ill effects.
Zelek
Hutto, TX
2021 Mustang Mach 1
If you're not getting any additional timing from running the extra ethanol, then all you are doing is wasting more gas to achieve the same thing. Get a tune or keep wasting money. Your choice.
K4fxd
NKY
You will get more timing. The ECM senses knock and if it finds none adds spark till it finds knock or runs out of adjustment range.
Soulja4187
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
Terry are you from south florida?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
What does it trim out at when running E30 ?
beefcake
Bethel
2018 Ford Mustang
K4fxd
NKY
K4fxd
NKY
K4fxd
NKY
You work your way up to WOT.
If you know how to read logs it is not dangerous.
