e85 questions
tmilliner24
tmilliner24
Louisville
Tony
2011 mustang, 2021 GT
2021. Getting ready to order the Wengerd returnless system and tune. I think I’ve read some of your information on this system. Are you of the opinion that it is capable?
RMoeslein
Pittsburgh
Rich
2022 Mustang Mach 1, 2020 f250 lariat Tremor
engineermike
La
2018 GTPP A10
The GT500 fuel module is amazing and running dual FPDMs with full PCM control is the way to go. A few things concern me about the setup in question: 1) You lose diagnostics on the 2nd FPDM so if the pump/wiring/FPDM fail then you don't know it until it's too late, 2) I don't think they include a proper fuel filter, and 3) there is an issue in the GT500 bucket where it won't pull fuel over from the passenger's side saddle with the GT internal plumbing and I don't know if they've properly addressed it.
As for flex tuning, the Gen3+ PCM has excellent logic for managing flex fuel. You can float borderline timing, boost, and dozens of other parameters with learned ethanol. Many tuners miss the necessary parameters to make it work, namely because HPT never defined them, while many other tuners don't fully exploit the capabilities of Ford's flex logic. If they're relying on knock advance when running ethanol or have cold starting issues, those are tell-tales the flex tune is half-baked.
tmilliner24
tmilliner24
Louisville
Tony
Mike,
Thanks for taking the time explaining this. I will discuss these items with Wengerd and see if he has addressed them. I have a lot to learn about e85 and fuel systems.
5.0_Lojos
Miami FL
Carlos
2016 Mustang GT Premium
Just wondering where boosted (ess) guys get their e85. Do you trust pump fuel and if so what station/brand? Looking to move up from my 93 and know nothing about the do's and don'ts of e85. Getting ready to purchase a returnless fuel system and injectors from Wengerd.
I was facing the same delima and I just pulled the trigger and did it. Its probably best thing to do. Now, my car isn't a daily driver it does consume about 20% more fuel I believe is the %.
Wolfys11
New york
Jakub
2023 Mustang Gt
Mike,
Let us know his responses, i am likely going this route over summer with his system as well
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Downsides are ethanol is MUCH less dense so expect fuel mileage to go down to like %60 of normal mileage.
Dont let it sit in the tank. Water accumulates in the lines. My car sat for a few months and there was quite a lot of water in the lines after 4 or so months.
Ethanol is hell oil longevity - change your oil like 2x as offen.
Finally, most of the E85 is 85% ethanol (which is all effectively the same quality) but the 15% left is *low* quality gas. Thats the difference between E85R and E85 is the 15%. Generally still worth it, if you dont mind having to fill up on your way to filling up. The engine loves it, just needs a bigger gas tank.
I carried a couple syringes and an empty gatorade bottle around to test the ethanol content which was awkward to say the least.
diambo4life
OKC
2014 Mustang GT 1998 GSX
I run OnCue E85 and I have done so in multiple boosted vehicles (Mitsubishis and Fords) in the past 20+ years. Never had to test it. Ever. At my local RS Fuels gas station, the employee there routinely posts in our local FB group the CoA when they get a new batch of pump E (they even have E100 at the pump) and it's always 80%+ E content even in the winter. My Mustang has an installed ethanol sensor that I plan to finally setup the hardware to detect E content just as a datapoint however. I run E85 all the time even in the winter time and my car starts perfectly fine even in 40 degree weather. My old Whipple F150 that was tuned by Oz also started up in 30 degree weather perfectly with E. I have no reason to even run pump gas in my Mustang unless I had to travel out of town beyond the driving range of my gas tank and didn't have access to E85 enroute.
tmilliner24
tmilliner24
Louisville
Tony
I went ahead and purchased the Wengerd returnless fuel system last night. Wengerd got back to me and said he has taken care of any starvation issues with his system. Thanks to all that chimed in with info. It was much needed. Now that I know I’m going e85 with a flex tune on an ESS 120 pulley, should I go fic1000 or id1050x injectors? Is the step up in price for the 1050’s warranted?
Wolfys11
New york
Jakub
2023 Mustang Gt
Ask Wengerd which he prefers. Always ask your tuner.
This^
However i usually hear the 1050s are worth it in every time i hear this question
robvas
MI
2011 GT
This^
Yea, assuming they match your horsepower goals I don't think anyone is going to advise against the ID's
The FIC or DW's are a little bit cheaper, but you don't want to end up being the guy that buys all the parts before talking to the tuner, and when you finally do, they tell you they don't want to tune it unless you buy different parts.
Wolfys11
New york
Jakub
2023 Mustang Gt
Do 1050s on gen3 support 900whp on e85? I thought they did with supplemental di
