Do I need 50w oil?
Ptrug
Phil
2019 Mustang GT Premium PP Convertible with FI
G2, 120mm on 93.
I don’t track her and rarely WOT but I def drive her hard.
Should I still put 50w as a precaution? Thinking mobile 1 super car which is 40w. Currently on mobile one 30w.
Thoughts?
Gregory347
LI, NY
Greg
2019 GT A10 PP1, 1987 Buick Grand National, 1985 Mustang
I run Valvoline European 5W-40. Good oil and fair price at Walmart. I ran Motorcraft synthetic 5W-50 for couple oil changes but read it shears to 5W-40 rather quickly and it more expensive.
CrackedHorn
Kansas
09 Mustang GT/CS; 15 Mustang GT
30 or 40 weight is fine for a centri blowers and street use.
Lots of good options as far as brand of oil. More import is the oil change interval.
EFI
Masshole central
5.Br0
You only need thicker oil when you plan on taking it past normal operating temperature.
You need to maintain a certain viscosity based on internal clearances. At high temperatures, viscosity is reduced so that's why people go with a 40 or 50 weight oil so that as it thins out it gets back to the original requirement for viscosity. If you don't take the oil past 230*, then you don't need anymore than 30 weight. Also quality is more important than weight, I'd rather run a high quality full synthetic 30 than a crap quality 50.
Ptrug
Ptrug
Phil
This is the answer. Thank you!
But let me ask you, if I can get mobile, one supercar, which is 40w, probably still a better choice, correct? Or is it irrelevant in my situation?
EFI
Masshole central
5.Br0
It's basically irrelevant. For your needs it's going to perform just as well as a quality PUP 5w30.
Ptrug
Ptrug
Phil
PUP over Mobile One?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I would err on the side of thicker. If not needed for temps it is better for the cam phasers. The thicker oil holds cam timing better, which is why I run 40 weight in a N/A engine.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Me too. 5W40.
12-13 BOSS Mustangs used 5w50.. and 95% of the owners never track them
Ptrug
Ptrug
Phil
Yup, all day every day.
That's not to say the Euro spec M1 is trash, just would not be my first choice.
My local shop carries 0w-40 in the PUP and 5w-30. I know your comments about not needing anything above 30w but I am curious if the 0w to 5w make any difference if I err on the side of using 40w?
