Direct injection
Shadow277
Arizona
2016 Mustang GT 2012 Corolla
If the math works out in your favor that well that's a no brainer IMO. DI isn't a new technology, VW and Audi has been using it since the early 2000's at this point. I personally don't have any concern about it lasting the expected life of the vehicle, if the oil changes are done on time (since the pump is cam driven).
So I gotta ask, how are those German engines?
Shadow277
Arizona
DI doesn't cause any valve buildup in itself. It removed the port injector which actually keeps the valves clean. If you have both, you get the benefits of both without any drawbacks.
But the carbon comes from DI, not port. Isn't the fuel pump also the same size? How does it keep it with demand?
EFI
Masshole central
5.Br0
Carbon build up comes from lack of PI that helps clean the back of the valves.
If you car has PI, it doesn't have carbon build up. It has nothing to do with DI itself.
Shadow277
Arizona
I do not see the connection.
engineermike
La
2018 GTPP A10
One of my favorites subjects. I’ve been experimenting and tuning the gdi system on mine for close to a year. A few points:
- The primary purpose is knock suppression. The direct injection vaporizes quicker in a larger volume so it cools the air, as opposed to the port and intake valve.
- There is a power advantage from gdi alone, even without higher compression. The rapid cooling of air in the cylinder during the intake stroke condenses it and helps draw in additional air.
- Particulate emissions are worse with gdi. I think this is the primary reason they kept port, distantly followed by valve-cleaning. (Fords di timing on the di-only Ecoboost works pretty well in keeping the valves acceptably clean.) They use mostly port injection at idle and light loads.
- You can’t just turn off the gdi injectors. Well, you can, but the injector will overheat and blow out. Some amount of fuel flow is maintained at al but the lightest of loads, in order to cool the direct injector tips.
- On the flip side, the port injectors are never phased out completely. I think this has to do with a delay. They will switch an injector off, which happens more than you think, then turn it back on. With port, the first squirt or two wets then port and valve so it doesn’t immediately reach the cylinder like direct. This would cause a temporary lean condition. Ford doesn’t command less than 10% port injector flow.
- Gdi injector timing and pump control is a fascinating subject for a nerd like me. It’s not really what the thread is about so I’ll reserve that for another discussion. I have modified my gdi pressure and found the limits of injector open and close timing. The speed and accuracy of control in the pump and injector is absolutely astounding.
mangosmoothie
Flagstaff
Casey
2019 Boolet
The carbon comes from some combination of combustion PCV and EGR. Port injectors wash the valves and carbon never has a chance to stick.
DI only has nothing washing the valves so the carbon sticks and builds up. DI is not the source of the carbon.
Shadow277
Arizona
PCV and EGR?
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
The point is worth 4% ? Lol. Total hp is 5.5% difference. Now, there's also a bigger camshaft. Bigger intake manifold. Bigger air intake. Going from 11:1 to 12:1 cr isn't the same as going from say 8:1 to 9:1 cr.
It's fairly well established that one point of compression is good for a 3-4% bump with all else the same....
Shadow277
Arizona
Keep trying then, it's been explained to you by several people on here that DI itself does not cause carbon buildup on valves.
That's why I asked what PCV and EGR is.
IPOGT
Alan
Pros and cons for deleting the direct injection on 18 and up mustangs
Aww, just throw an Edelbrock intake and a Holley 650 on it with vacuum secondary’s and you’ll be fine. May have to change the throttle linkage a bit
adjust the power valve and re-jet though. :cwl: :like:
EFI
Masshole central
5.Br0
EGR is exhaust gas recirculation, where it takes some of the exhaust gases and passes them back into the intake manifold to be burned again. The Mustang doesn't have this.
PCV is positive crank ventilation, where it takes the excess pressure from the crank case and passes it back into the intake manifold. This is where oil vapors get dumped into the intake and without a catch can will settle on the intake manifold, runners and valves as carbon deposits. PI usually cleans the valves off this stuff that's why the Gen 3 doesn't have this issue.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Actually it does, sort of. Ford gets EGR from cam timing at cruise.
Shadow277
Arizona
I can see why some owners add catch cans. Peace of mind.
