Delete DI on Gen 3 Aluminator for 2015 install?
Bleedfordblu
223252gt@
Walter
2015 mustang gt pp
Don't know the difference in with the intakes and other compatibility problems...but why not delete DI on a gen 3 aluminator for use in a gen2 car?
robvas
MI
2011 GT
You would have to get some sort of fuel pump block off and injector plugs or something
can you run a gen 3 engine with a gen 2 ECU?
Bleedfordblu
Bleedfordblu
223252gt@
Walter
2015 mustang gt pp
Well running gen 3 with gen 2 electronics becomes easier if no DI is used...right?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Ford changed the exhaust cam phazer on gen 3 so the only way this will work is if you use gen 2 heads. I'm not sure if a gen 3 ECU will run a gen 2 car.
Bleedfordblu
Bleedfordblu
223252gt@
Walter
2015 mustang gt pp
Ah that's definitely a problem!
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Just rebuild a gen2 . Sleeves are superior IMO.
wingnutt
@FL410
michael
350R Procharged w/P1X
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I’d get a gen3 shortblock, with gen 2 type heads and electronics.
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
Gen 3 bottom, Gen 2 heads, Gen 1 timing/chains gears. While you are at it get the upgraded OPGs, chain and sprockets.
K4fxd
NKY
Robottrainer
Canada
K4fxd
NKY
Should run run with a Gen 2 ECU since the business end is all Gen 2. It wind care about the short block or cam drives
So to tune it would need to go back to gen 1 timing range?
Robottrainer
Canada
In my opinion it would be the same tune you would use in a Gen 2 since the heads, cam and phasers would dictate the tune, and of course the induction system you plan to use. Something like this would lend itself best to a dyno, but I think the base point would be Gen 2.
K4fxd
NKY
Gen 2 has a mid lock intake cam phaser, gen 1 does not. This is where my question comes from.
Lots of tune changes required.
I think I'd stay with gen 2 timing components.
