Cylinder head temps??
RacerX661
RacerX661
@RacerX5.0
Phoenix
2017 Mustang GT Roush
Guess I need a thermostat! Thanks for all the reply’s. Has anyone tried the mishimoto 160 Degree?? Also any write ups to install it?
smann
Toronto
2016 GT PP
Max I get sometimes is about 210 F. This is in stop and go traffic or cruising at lower speeds.
When I'm WOT, the temp drops to about 200 ish
Chris Barnes
Arizona
2021 GT500
I just installed a Reische 170 deg in my 2018 GT. I'm finishing up the procharger installation this weekend and will let you know my findings. Prior to the supercharger and with stock T-stat I'd see cyl head temps of 210-219 in stop and go driving. Should be a good test since I'm in AZ as well.
ahl395
Allan
General consensus is the 170F is the best option. 160F seems to be a little too low.
3beeps
www.instagram.com
'17 GT
Your coolant temp DROPS when you go WOT? :confused:
ahl395
Allan
Compared to sitting in traffic, that's normal. Sitting in traffic temps rise with not much coolant flow or airflow. Once you go WOT you have more air flowing through the radiator and higher RPMs spin the water pump faster which will drop temps.
3beeps
www.instagram.com
'17 GT
I mean, of course your temps will be lower when moving than when you're stationary. No one would argue that.
But when you go WOT, you can watch your coolant temps climb in the logs.
ahl395
Allan
They do climb during WOT, but even to 160mph I've never had coolant or head temps reach what they do sitting in traffic. Trans temp however does.
Ruiner46
Colorado
2016 CO GT PP
160 really isn't too low, it's actually what Whipple includes in their kits I believe. The problem with the 160 is that it doesn't flow as well or open as far as the Reische 170. So using the 170 will actually result in lower temps.
smann
Toronto
2016 GT PP
Yup same thing for me, all the extra airflow.
Chris Barnes
Arizona
2021 GT500
Quick update: I just completed my procharger stage 2 installation. Haven't driven it yet, but let it idle in the garage for 30 minutes with AC cranking. Cyl head temps maintained 192-198 degrees, and it was 112 degrees out when I was letting it idle. I can tell you for sure that this car NEVER ran this cool when bone stock, even in cooler ambient temps. So far it's thumbs up for the Reische 170 deg thermostat! I'll update tomorrow after I get the front end put back on the car and drive it around. Cheers!
moffetts
San Mateo CA
Black Whippled 2015 GT PP
The real test is driving it in traffic on 140+ degree asphalt. Sounds like you're off to a good start, though.
Chris Barnes
Arizona
2021 GT500
I just got home from a 35 minute drive around town. Saw 206 deg once, but stayed steady from 199-204 most of the time while sitting at lights. That's literally 15 degrees cooler than before I installed the supercharger and Reische thermostat. By the way, outside temp was 110 when I was driving with 124 deg inlet temps on the dash. Ugg, I hate Phoenix in the Summer!
Crackerjack17
WV/Maryland
2017 GT PP
Yep. That's where mine sits. It was 80 out today. CHT was 195-198, coolant temp in center gauge said 185. Moves around a ltitle bit, but not much. I'd have to check my logs for exact numbers, but it does climb pretty fast when your wot through the gears. As expected. The reische 170 works!
