Couple of Random HPDE Questions
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
When I've run in sport plus mode I've destroyed my rear pads. I've melted through track pads with that setting, so I'll only do sport plus if it's mixed conditions or heavy rain or something. Track tends to be mostly ok, it only freaks out on huge elevation changes, like going over a sharp hill I can feel it cut power. It may be doing more that I'm just not aware of. Track mode does not seem to eat my rear brakes up though.
I'll risk a set of pads over the whole car. Especially when I'm new at it. i have a very agressive style and would appreciate traction and stability control while I learn how to drive on a fast track should I ever go to one.
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
Track mode still keeps 20-25% of TC and stability.
I found out i was much safer on the track with track mode more than sport .
Sport was intervening so many times that I couldn't predict ..it was dangerous IMO
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Really? I thought track mode turned them all off?
Flyhalf
CA
www.youtube.com
Alessandro
That is advance track mode
I did like you. I said. I want sport cause I'm aggressive .Then i lost the rear brake and i understood the trackmode is better :)
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
Track mode is simply reduced TC. There is still some. You can hold the switch down to completely turn TC off but the car can still turn it back on if it thinks the car is in a dangerous situation. This is why people just pull the fuse or plug so it stays off.
kz
West Chester, OH
Mustangs & F150
Track mode has traction control off and significantly reduced stability control (Advancetrac). Holding traction control button for 7 seconds turns off stability control completely and at this point nothing is left (except ABS).
Sometime you can get a message while driving (you have to be driving hard though) "Service Advancetrac" which makes the car go to Normal mode and everything comes back on.
Bay Area, California
Non
2019 Mustang Ecoboost (Premium Plus, Perf. Pack, Ruby Red)
Wait a minute. If a person gets in a mustang, starts it up and holds down the disable button for 10 seconds (shutting off advancetrac and esp), it can possibly turn back on again on its own? Like, say if someone was doing spirited driving in a windy mountain road and skidding alot?
...If so, my next question is this: how necessary is ABS in life, and can I go without it?
raiderjatt02
Bay Area, CA
Jessie
2016 GT350 - Track Pack; 1995 GT - Saleen Clone
Yes, but I've only had it happen during Autocross on sticky tires because of the quick and harsh changes in direction. It never happened on my stock MPSS tires because the G forces never got that high.
That said, I run Track Mode every time I'm on a road course. It allows for just enough leeway to where it doesn't intervene too much but when it does, it's usually to save your ass from spinning out. I'm not comfortable enough on track to risk turning everything off at those high speeds. I turn everything off for autocross though.
As for ABS, no, don't ever turn that off or get rid of it. The ONLY way you'll benefit from no ABS is if you're the second coming of Ayerton Senna. And even then, ABS will still probably save your life one day.
kz
West Chester, OH
Mustangs & F150
Don't know how likely it is to happen during spirited driving (IMO - highly unlikely) but yes, it can definitely turn back again on its own. Happened to me many (unfortunately) times.
Very - especially if you do any kind of spirited driving with hard braking. Try driving an old car without one (friend had an old JDM MR2, I have '65 Pony), you'll see - if the car has good brakes capable of locking the wheels.
