Bluemustang
Actually, I think this might be it Norm. I second.It might be time for some IRS bracing.
The only time I've experienced something that could be described anywhere near like what you have noted was when I took a tire pressure staggering test sequence to a truly foolish level, where the tail was loose under both leading throttle and trailing throttle. In that case, it was rear tire pressures too low. In your case, maybe you're running the rear tires at too high of a cold pressure, or perhaps they're gaining an unusual amount of pressure for some reason. Not enough rim width for the tire size could be at play here as well. Street tires aren't built like cantilever race tires to get around class restrictions on wheel width.
Norm
