Convertibles Photos Thread
spogshd
manchester uk
2016 convertible
Up to date photo.
Fordever
NL, Canada
Derek
2016 GT/CS Convertible
I LOVE those wheels. Looks like they would be easy to clean too. :)
Yes....easy to clean. But I wish they were wider. My tires are 255 wide and that's as wide as I can safely go with these CS wheels.:headbang:
spogshd
manchester uk
2016 convertible
Too subdued.
At some point you should come out of your shell & shout,
“I’M LOUD AND I’M PROUD!”
LOL Bob, that's the reaction I'm looking for.
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
Hi Derek, I thought the CS rims could accommodate a wider tire, I know the stock tires are 255/40, but I thought you could put a wider tire on there... if that is not the case have you considered spacers? I think CJ's has some 25mm that are pretty conservative. I have read both good and bad about the spacers though...
Fordever
NL, Canada
Derek
Hey Lorne, our rims are only 8 1/2” wide. Our stock tires are 255mm or 10” wide. Going wider would give more bulge on the walls. My fear is more outward sidewall pressure.....a good bump and popping my tire. Maybe me just being paranoid. But for me, better sake than sorry.
And BTW, I have 20mm spacers now. I have been running them for the past two driving seasons. :)
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
Thanks Derek.... I actually meant 20mm.. I guess some of the horror stories i've heard about spacers coming loose and constantly having to worry about rechecking the torque kind of scared me away from them. I love the look of the CS rims- much more so than the stock rims on my coupe, but really want the tires more flush with the fenders.. What brand spacers did you buy and do you have to check them periodically? I know that hub centric is the way to go..
Fordever
NL, Canada
Derek
Hey Lorne, You will get both side of the adapter (spacer) argument, but personally I have had no issues with mine. I did a lot of reading on the subject before purchasing mine. I found a set on ebay…..yes, I know.. :), but after doing a lot of looking and reading, I concluded the ones I purchased had the same grade aluminum and the same grade lugs as the lugs on my hubs. After I installed, I drove for 100 miles or so and rechecked my torque. All were good and I still periodically check....never had an issue....so far. I used some anti-seize between the hubs and the adapters as some members here have had their adapters 'Stick' to their hubs and this may be an issue if you ever want to remove them.
Here is a link to a thread I started on the subject some time ago. Its long, but there is a lot of good info in it, including the ebay link to the adapters I purchased.
https://www.mustang6g.com/forums/threads/wheel-spacers-20mm-or-25mm.72987/
I am am neither recommending or discouraging the purchase of the spacers I purchased, just giving as much info as I can to let you make your own informed decision.:like:
