Cheap diy suspension mods?
stannypack
NOVA
2022 Mustang GT
As bad as it sounds I just want to mod my car for the sake of modding my car, don't ever plan to track it and just do spirited street driving.
Also don't plan on lowering the car. Need some diy mods I can do just to make the car "handle" better. I say "handle" because it feels fine to me as is, but I want to work on my car more lol.
I plan to whipple it in the future, so I guess I could look for the best mods for hard straightline pulls? Both steeda and bmr have so much stuff it hurts my head researching. I know when I go whipple it'd be good to upgrade driveshaft, clutch, and axles
SSG 5.0
2017 Mustang GT
Cradle lockout and IRS braces should be easy install.
galaxy
St Louis
'17 GT350
First and foremost, thank you for using air quotes correctly, hahahhah! And I get it. I do mods for the sake of mods. It's the drive, not the destination. I plan mods all the time to be able to work on my car in hope that I'm actually making it better in the process. As for affordable suspension mods that actually made a difference, the following come to mind;
sway bar end links
vertical links
subframe bracing
This is where I started and ejoyed every one of them. In fact, the only other thing I've done is springs and sway bars (N-5700-M kit). (I take that back; I did SPC camber and toe arms also) I will do no more. Not messing around with any bushings or components that may induce NVH, but that's just me. As I've gotten older, I've done a much better job of balancing the mods I choose against the reality of how I plan to use the car. And not that it's any slouch to begin with, but you get it....
tj@steeda
Timothy
Steeda IRS Braces are one of the easiest installs with some of the best bank for the buck!
Onewolf
East Tennessee
2023 Ecoboost Premium Convertible
Is there a version of the IRS brace that works on a convertible? Thanks.
tj@steeda
Timothy
Unfortunately, No - there is extra bracing & further modifications that would need to be done - other parts of the Stop the Hop Kit do fit.
Best Regards,
TJ
boB
boB
2019 GT PP1
DIY alignment is low cost. So is adding negative camber by slotting the strut.
stannypack
stannypack
NOVA
2022 Mustang GT
Thanks all, I think I'm going to go with the FRPP track handling package since after installing my new wheels I definitely need to lower the car lol. And would rather have a full set that's designed to work together than trying to piece together a bunch of different parts and make a frankenstang :crazy: after that I'll see what needs to be done
tj@steeda
Timothy
Well, that went from cheap DIY mods to a full-blown suspension build, lol.
Let me know if I can help put together a similar package with potential Memorial Day Savings.
Best Regards,
TJ
SSG 5.0
2017 Mustang GT
So I’m assuming this FRPP track handling package is better suited for track use correct?
stannypack
stannypack
NOVA
2022 Mustang GT
I've been doing research and seems it's fine for daily driving. The street handling package is basically the GT performance pack 1, and if the whole car's being ripped open I'd want something more substantial lol.
Best Regards,
TJ
Thanks, still doing research but after installing my new wheels I realized how big the wheel gap is, thus leading me to now researching springs and good parts that work well with them
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
You want better handling or straight traction? You can’t have both.
Handling=Wide low profile tires, stiff suspension, aggressive camber negative angle.
Forward traction= None of the above.
stannypack
stannypack
NOVA
2022 Mustang GT
I won't be supercharging for a while so for now more handling focused, but eventually I'd be moving towards the forward traction route
Cory S
Bradford, NH
Cory
