Chassis stiffness and flexing on inclines
JOKER M1
Somewhere in Indiana
2015 GT Premium (SOLD)
It sure makes a world of difference when done right. My garage floor has a very cheap epoxy job supplied by the builder. If you look at it wrong it might start chipping. It definitely can’t handle having anything dropped on it. Our previous house had the garage floor done right like yours. My current garage has been through a lot because of incompetent tradesmen. It looks nice out there, but the floor is some ish.
RaceDeck was great except being up north with the salt and my wife daily driving the seams in the RD tiles would get salt crystals and it drove me nuts. You wouldn’t have that issue in FL
NGOT8R
Adrian
2019 Bullitt
Yeah, that might be my next move.
swoop1156
22 Mach HP, 22 Raptor 37PP, 22 Cayenne Turbo SE
My AWD Edge ST also doesn't flex much and it freaks out when I (sometimes intentionally) hit an angle and incline simultaneously. The Mach? Lol if I hit a pebble it's on three wheels 🤣
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Yeah mine lifts the same way, haven't had any issues. Makes funny noises with the torsen diff but no biggie I would not worry. These cars can take on a full lunch from stop just fine this is childs play for the drive train/suspension.
Paul McWhiskey
United States
Paul
2017 Mustang GT Premium w/PP
Should you find yourself in a situation where you have one rear wheel off of the ground while crossing a steep roadway/driveway transition and the car stops just apply a bit of E Brake and you can easily drive on. The differential will do what it is designed to do.
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
RagmopInKona
CEO
2020 Mustang HHP
So, I'm curious... At my work, we have quite a large transition from the roadway into the parking lot. I definitely have to hit it slow on an angle coming and going. But I make it without scraping luckily. I've noticed the chassis is so stiff that one of the rear tires actually leaves the ground when I make the angle and go across the drive. I then feel the rear seems to jerk a little. I'm guessing from the torsen diff. Anyone else notice this? Anything detrimental about the one wheel leaving the ground on the drivetrain and such?
I want to see this incline that you clear the front spliter but the IRS wheel droop isn't enough to stay on the ground.
Dana Pants
Burlington MA
Dana
2018 GT PP1
I have also experienced this situation repeatedly at the entry to a specific restaurant. Rear droop = zero. With the snow tires, I would probably benefit from disconnecting the rear swayba because the inside rear is always trying to spin. Too bad I won’t.
RobZ71LM7
Louisville, KY
Rob
2021 Mach 1, 2019 F-150
Not to hurt anyone's feelings, because the S550 is a lot stiffer than older pony cars, but.... my '94 F-body hardtop did all of these things and that was before it had subframe connectors.
swoop1156
Just wanna have fun on Friday and say that my Mach 1 doesn't just flex on inclines 💪
