Catch can...2and question
hoot12
mississippi
wes
2020 gt500 Black
Most catch cans by upr or jlt have ways to service them. Does the Ford oem catch can get serviced and if so how.
Can someone explain how this catch can works.
Thx
Epiphany
Global
I like to disassemble things.
And you said you installed it?
V00D00
Dover DE
2020 GT500
im working on a custome one. Ford recirculates, the others are servicable
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
If someone really wanted to, you could just run the drain tube from the Ford catch into a Bob's can (or the like) to collect and dump the oil, as opposed to letting it drain back into the engine. I would trust the Ford engineering over aftermarket for the filtering of the oil, this would be a best/best option for some.
Personally, I see no reason to collect and dump. The oil most see with froth, is from the filtration design of the aftermarket catch. The oil from the Ford catch will look, well, like oil. That, and the fact it mixes with nearly 12 quarts of oil, and is filtered by a well designed cartridge filter, and only spends 3-5 thousand miles in the engine. I for one am not concerned.
hoot12
mississippi
wes
2020 gt500 Black
Yes I installed the catch can myself. Not a hard process at all. It definitely didn't appear to be serviceable like the aftermarket ones. I'm wondering if that is why I experienced some white smoke upon starting up for the first time after install....because it was new and recirculates.
Epiphany
Global
I only asked because it is rather self explanatory as to how it works. You could service it if you felt you had to but you would have to remove it from the bracket and place it on a table for disassembly or you could remove the STB which would give you access to the top cover bolts on the separator. However, with the drain in place there is really no reason to have to take it apart.
Jmeo
You said member ;)
Massachusetts
Jaime
I was bored today, so I decided to peek into the optional, factory designed & built, oil catch can. My car only has 700 miles on it, and as you can see in these pictures, it is already catching oil.
Also, the oil mist is being captured and returned to its original form before it drips back into the cam cover. This satisfies my theory that this being designed by Ford engineers means the catch will work properly, and return OIL to the engine, not the frothy crap substance that most aftermarket cans produce. I am very happy to see this.
Snoopy49
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
Also, the oil mist is being captured and returned to its original form before it drips back into the cam cover. This satisfies my theory that this being designed by Ford engineers means the catch will work properly, and return OIL to the engine, not the frothy crap substance that aftermarket cans produce. I am very happy to see this.
I have the Bob's catch can on my 2013 and the oil in it has always been clean, I would put it back in the engine, but it would be more work than it was worth seeing that there was only an ounce or 2 in the separator. I have never had to add any oil between oil changes on the 2013.
Jmeo
You said member ;)
Massachusetts
Jaime
I haven't used Bob's can, but I have used JLT, UPR, Moroso, and Misimoto. All of them produced frothy crap, I can only assume due to the style of their cans. I mention this only because some people were hesitant to return the collected fluid back to the engine, because of how ugly the froth from other cans looks.
Snoopy49
Earl
That would certainly explain some of the peoples reluctance to embracing the new style catch can from Ford.
