Car running and Exiting with the remote - HONK
yessirrom
DFW Texas
2017 Magnetic GT Convertible
hawkbox
Arizona...in the heat
'18 GT Premium PP
anyone done this on an 18 yet? are the as-builts the same?
hlh1
Central VA
2019 GT PP1 A10
hlh1
Central VA
2019 GT PP1 A10
Ok, now that I have this stuff I'm not seeing on the Android app where to make the change to stop the horn.
Ah, now I need to get Forscan.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
You need to conect with the Pc app. The mobile app is not at all the same thing.
hlh1
Central VA
2019 GT PP1 A10
Downloaded it. Look like I need to get a free license to run it.
ctandc72
VA
'19 GT 6 speed Base
Go to that original 'Modifying As Built Data" thread. First post.
Download FORSCan. Join the FORScan forum (free). Activate membership. Then follow instructions to activate FORScan the program. After that find the data you want to change, plug up and make changes.
hlh1
Central VA
2019 GT PP1 A10
Doing this now. thanks!
cjldad
Richmond, Va
2017 GT PP
Is there a way to set it to where you can lock the doors with it running and the keys out of the car?
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
In case you haven’t figured this out, this is the way to do it via FORScan:
Double Horn Honk Reminder (Engine on, Keyfob not in car):
Code: 726-41-02 xxx1 xxxx xxxx - Enabled
Change To: 726-41-02 xxx0 xxxx xxxx - Disabled
I found on eBay this adapter that works perfectly with FORSCAN, as it can read and write HS and MS-CAN modules, without the need of an expensive Bluetooth or WiFi adapter:
ELM327 USB modified for Ford ELMconfig FTDI chip HSCAN / MSCAN Forscan OBD2
https://www.ebay.co.uk/itm/ELM327-U...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
It's of great quality and very easy to use.
ctandc72
VA
'19 GT 6 speed Base
Since yesterday.. :)
Seriously though, when I exit and close the door I get the double honk.. Then when I try to lock, double honk again and no lock..
Check to see if a door is not closed all the way. That happened to me the other day.
