SidewaysMike
- Oct 28, 2014
- Somehwhere in the Med
- Mike
- 2016 GT PP
Has anyone found the universal windows up from the key fob code?In case you haven’t figured this out, this is the way to do it via FORScan:
Double Horn Honk Reminder (Engine on, Keyfob not in car):
Code: 726-41-02 xxx1 xxxx xxxx - Enabled
Change To: 726-41-02 xxx0 xxxx xxxx - Disabled
I found on eBay this adapter that works perfectly with FORSCAN, as it can read and write HS and MS-CAN modules, without the need of an expensive Bluetooth or WiFi adapter:
ELM327 USB modified for Ford ELMconfig FTDI chip HSCAN / MSCAN Forscan OBD2
https://www.ebay.co.uk/itm/ELM327-U...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
It's of great quality and very easy to use.
or to change the radio from US frequencies to Europe?
